Old 03-09-2017, 10:26 PM   #1
spookybathtub
Drives: 2007 Yaris HB
Blower only works on LOW
I swapped the green bulbs inside the climate controls for LEDs. Since then, the blower fan only works on low (setting 1). On 2, 3, and 4, the blower doesn't run.
When I turn the switch from 0 to 1, I hear the heater relay click on. When I turn it from 1 to 2, I hear it click off. Turning it to 3 or 4 makes no click, since it's already off. So for some reason, the relay isn't turning on with the higher settings.
Voltage at the blower connector measurees 12V on setting 1. The other settings show 0V.
I removed the blower resistor and did 3 measurements as shown in the service manual. All three are slightly high (by about 0.4 ohm), probably just due to age and/or cheap leads on my meter.
I removed the blower switch and measured resistance as I rotate the switch from 1 to 4. I get continuity between pins 5-9, 5-10, 5-6, 5-7, respectively.
spookybathtub is offline   Reply With Quote
Old 03-10-2017, 10:56 AM   #2
Did you think to try changing back the leds for bulbs? Also make sure bob of the wire that connnect into the fan switch are loose.
Old 03-10-2017, 11:32 AM   #3
spookybathtub
I figured it out. After going through a wild good chase with the multimeter, I realized the blower switch wasn't snapped back together fully. Duh!
Old 03-10-2017, 11:33 AM   #4
Glad it was a simple fix.
Old 03-10-2017, 12:14 PM   #5
Fan Blower Only Working On 4 FIX!!! jasonk1123 DIY / Maintenance / Service 2 06-07-2014 04:24 AM
