Old 03-17-2017, 10:21 AM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
2zrfe Engine swap - $500 picked up
I am selling my engine swap stuff:
2zrfe engine, about 70k on it. Needs intake manifold and throttle body
Xd auto ECU
Xd A/c compressor
Xd alt
Oil filter housing tool
Wiring harness - currently setup to use the ABS module to get the speed signal. Literally just needs the pin popped into the ABS connector
All necessary engine mounts.
Pretty much all you will need, other than the intake setup, is the exhaust.
Looking to get $500 picked up for everything. I am located in near Ebensburgh/Johnstown, PA.
I have an engine crane to help load it onto a truck or trailer
I can post pictures later, but you can see my build thread here: http://www.yarisworld.com/forums/showthread.php?t=56233
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
