Old 05-20-2007, 12:41 AM   #1
Eurostar
hello
Superturismo Anyone?
hey guys, I'm looking into wheels for the Yairs, and I happen to like these alot
what do you think? how will it look on the Yaris HB
does anyone here have those on their Yaris?, I'm think about 215/40R17, how much do you think I should drop with that size to get a perfect gap, let's say no higher than an inch cap, thanks guys
BTW they are costy, specially for the 17s
Eurostar is offline   Reply With Quote
Old 05-20-2007, 12:53 AM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Nice wheel, but I bet a real bitch to clean.
blacksan is offline   Reply With Quote
Old 05-20-2007, 01:03 AM   #3
drooooooool....
Find the garage of a member here called Mister Kill, he has those on his first generation Yaris, they are gorgeous...
Old 05-20-2007, 01:12 AM   #4
i've always liked those rims.
Old 05-20-2007, 02:44 AM   #5
http://www.yarisworld.com/forums/showthread.php?t=4298 to save some time searching
Old 05-20-2007, 03:01 AM   #6
Eurostar
hello
they look good, I think they are 15s and not dropped low enough, with more drop and bigger size would be even better.
Old 05-20-2007, 05:58 AM   #7
tca4
tca4's Avatar
Drives: Yaris RS (white)
I saw someone driving also a yaris with a rims looks SOMETHING like this and also a CF hood but he doenst seem to be on this forum.
tca4 is offline   Reply With Quote
Old 05-20-2007, 03:55 PM   #8
Eurostar
hello
Originally Posted by echo_hrs View Post
2cati had the OZ 17s on his Yaris, way back when we got them in October 2005...He also had the car lowered with the dealer Eibach/TRD springs...
Cheers
looks like the Eibach is an in drop , I guess I will go with the Tein S-Tech for those Superturismo 17s, snice thats the only springs brings down to a 1.9 in drop in the market right now.
Great pic, thanks
Old 05-20-2007, 05:35 PM   #9
the S.Tech's are great.
Old 05-20-2007, 07:23 PM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Those are favorite wheels, EVER! I would have gotten them if not for the price. Go fot it!!! 17's, 215/40/17's, and TRD or Tanabe NF210 springs.
Old 05-20-2007, 08:15 PM   #11
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
I realy like the look of that ..
tiksman is offline   Reply With Quote
Old 05-20-2007, 08:43 PM   #12
Eurostar
hello
for sure man, even though it's USD$250 a peice, i think those may be the most costy wheel for a 17s on the market you can get, but I dont mind the price because I think those are the best looking wheels you can get out there, I m gonna go with the 1.9in drop with the Tein S-tech, I dont think an in drop is enough to take away all the cap.
Old 05-20-2007, 10:07 PM   #13
Eurostar
hello
Here's the Specs
Finish Shown: White Painted
Size Selected: 17x7
Price: $249 (each)
Recommended Tire Size: 205/45-17
Wheel Offset: 40mm
** Lightweight: 21.4 lbs. **
Additional Specs
Bolt Pattern: 4-100
Finish Warranty: 2 YEARS
Country of Origin: ITALY
Construction Type: 1 PC LP CAST
it's a 40mm offset, and recommended 205/45-17, my stock tires are 185/60-15, to keep the same diameter of the wheels, I could either go with a 205/45-17 or a 215/40-17, I think I will go with the 205/45-17 since is recommended, is 21.4 lbs per wheel consider light weight? how much do theose OEM wheels and steelies and other aftermarket wheels weight?
Old 05-20-2007, 10:21 PM   #14
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Great pic, thanks
actually you could get coilovers, or there is also sprint springs offering 2.
you have some options
SPONSORED BY
Old 05-20-2007, 11:56 PM   #15
Walter
Walter's Avatar
Drives: Polar White LB
Great pic, thanks
Love the wheels, even more in white!
Get 205/40/17s and Sprint springs (2.0 inch drop)
Walter is offline   Reply With Quote
Old 05-20-2007, 11:58 PM   #16
PetersRedYaris
Stock 15 inch steel with 185/60/15 weighs 33 lbs.
Stock wheel diameter = 23.9 inches
215/40/17 = 23.9 inches (exact replacment)
205/45/17 = 24.4 inches (too tall)
205/40/17 = 23.5 inches (good choice for 1.9 inch drop)
21.4 lbs is fairly heavy. Your set-up will probably weigh ~42 lbs when mounted and balanced. Not a huge loss of power; mine is the same.
Old 05-21-2007, 12:12 AM   #17
Eurostar
hello
hey peter, how much do ur springs drop? ur set up loos perfect
Old 05-21-2007, 11:22 AM   #18
PetersRedYaris
I'm on Tanabe NF210 springs (1.1 front, 1.3 rear). My tires are 205/40/17. Wheels are 7 inches wide with 38mm offset.
