Old 03-20-2017, 10:48 AM   #1
miiser
miiser's Avatar
Drives: yaris 2009
K&N air filter noticeable difference?
Hi,
I am thinking of replacing my stock air filter to a higher flow K&N filter.
Are there any advantages over the stock one?
Any noticeable difference and any reasons to do that?
My engine is 1.3 101hp all stock.
Link for the filter:
https://www.amazon.com/gp/aw/d/B000N...VeL&ref=plSrch
miiser is offline   Reply With Quote
Old 03-20-2017, 11:14 AM   #2
With just the filter by itself and no other flow mods (exhaust, intake manifold, header etc) it won't make a noticeable difference in performance. The sound may change though.
Keep in mind I haven't installed that filter, but I'm basing my comments off of mine and others experience with a short ram intake.
Old 03-20-2017, 04:16 PM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Id stick with a stock filter. Its cotton and flows well for the given size.
Id remove the carbon trap in the airlid you will see more of a difference in that
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-21-2017, 02:49 AM   #4
bronsin
bronsin's Avatar
If you go KN make damn sure you don't over oil it. That will oil up the wires in the MAF sensor big time!
May happen no matter how you oil it!
Old 03-21-2017, 08:05 AM   #5
miiser
miiser's Avatar
Drives: yaris 2009
So maybe I shouldn't do it?
Old 03-21-2017, 09:15 AM   #6
Not really. Given the negligible performance gains, coupled with the cost/hassle of cleaning/oiling the thing, not worth it imo. May want to look into something like an AFE washable dry filter, or just stick with disposables.
Old 03-21-2017, 02:40 PM   #7
bronsin
bronsin's Avatar
My vote is the OEM filter from Toyota! Im 60 and in all my carowning life, its the best one Ive seen.
Old 03-21-2017, 05:59 PM   #8
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
On Instagram
On Wheelwell
Old 03-26-2017, 07:08 PM   #9
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I prefer to just stick to the regular OEM paper air filters for the engine & cabin, and change them out every Spring to keep airflow maximized and allergens/dust minimized (in the case of the cabin filter). $30-35 per year total isn't unreasonable (if you install yourself) - plus Arizona is one heck of a dusty+allergen state, so best to change them out annually.
Kalispel is offline   Reply With Quote
Old 03-26-2018, 02:24 PM   #10
crpt2008
Drives: Yaris D4D 2007
Hi,
1 - Advantages. Yes to KN (more profit). Not to the end user or your car.
2 - Wallet get's lighter, in spite of the weight loss. Performance gains are still to be found.
Much better of getting some new blinker fluid...
crpt2008 is offline   Reply With Quote
Old 03-27-2018, 01:33 AM   #11
komichal
Once I accidentally drove a few miles without any air filter. Honestly, I have not noticed any difference... Speed, noise... nothing.
Of course I have put the filter back immediately after I realized my fault. After all, we all know how the air filter looks after some time. But now I know that it does not make sense to get any "more breathable filter". They usually cost a lot more and they make no difference for me.
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
AEM Filter + K&N Cleaner = WTH Marie DIY / Maintenance / Service 5 05-25-2011 11:29 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Stealership faked a filthy cabin air filter kenora DIY / Maintenance / Service 14 09-15-2009 09:00 PM
