Old 04-02-2017, 01:56 AM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Timing cover reseal 🚗🚗🚗🚘🎈🎈🎈🎈
Hello Yaris world I'm going to atttemp to reseal the timing cover on my o7 hatch back Yaris since I can't stand leaks well seep in this case, and I have a few questions: I already bought the water pump, crankshaft seal along with a new timing cover, furthermore what are the torque specs for the timing cover? And anything else I should replace since I'm already in there and how long does the sealer take to dry up? thanks in advance
Ramon1691 is offline   Reply With Quote
Old 04-06-2017, 07:17 PM   #2
B.B._07
Drives: 07 5dr
There's a few different torque specs so take a look at the attached page from the factory service manual. For the sealant cure time I would follow the directions on the package of which FIPG or RTV sealant you choose to use. Toyota recommends a FIPG which have a very quick cure time compared to an regular RTV.
white carbon timing cover 1nz revolution Cosmetic Modifications (Exterior/Interior) 6 01-10-2016 06:23 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Cylinder head cover and timing chain cover fs ttr125fan09 Items for Sale by private party 3 07-03-2014 09:16 AM
wtf?! timing chain cover split?! jeff69dini DIY / Maintenance / Service 9 08-01-2007 12:11 PM
