Old 04-05-2017, 03:17 PM   #1
Lightyear
Drives: YARIS 1.0
Can I combine a French and a Japanese Engine?
I recently acquired a French built Mk1 Yaris 1.0 litre with broken engine as well as a spare Japanese engine which is also broken.
My question is, would it be possible to combine the engines (i.e) take the good bits from one and put them in the other) to create one good one? The French engines seem to be a lot rarer to find and I don't really want to have to remove the lump from the car, so I've decide to rebuild the French engine. The timing chain snapped but the valves are all intact, however the teeth on the cog at the end of the Crankshaft have been stripped by the broken chain. So would the crankshaft from the Japanese engine be a straight swap and fit without any issues? Are the internals from the French and Japanese engines different?
Thanks in advance.
Lightyear is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Finally Toyota starts cookin with their engines and trannies digitalrain Off-topic / Other Cars / Everything else Discussions 8 10-04-2012 10:10 PM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
