Old 05-30-2006, 02:25 AM   #1
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Alarm Install
Here's wiring information for security and remote start. Not all cars are the same, make sure you check every wire with a meter. My car is a 2007 sedan S type bought in Long Beach, CA
12Volts = Yellow(25Amp), Gray(15A), +, Ignition Harness
Starter = Black (X2 and are common), +, Ignition Harness
Ignition = Pink, +, Ignition Harness
Second Ignition = Green, +, Ignition Harness
Accessory = White, +, Ignition Harness
Keysense = Yellow, -, Ignition Harness
(Use this wire to disarm the factory alarm w/o unlocking doors)
Power Lock = Brown, -, Driver Kick
Power Unlock = Green, -, Driver Kick
(Meter wire while turning key in the driver door key cylinder, to
Unlock driver door only single pulse, double pulse to unlock
all doors)
Parking Lights = Green, +, Fuse Box
Parking Lights = White, -, By Ignition Harness
High Beam = White, -, By Ignition Harness
Reverse Light = Red, +, Fuse Box
Dome Light = Pink, -, Fuse Box
Driver Door = Red, -, Fuse Box
Pass Door = Blue, -, Fuse Box
Rear Doors = Yellow, -, Fuse Box
Trunk Pin = Lt. Blue, -, Fuse Box
Park Switch = Black, -, Gear Shift
Tachometer = Lt. Green, AC, Data Link Conn.
Brake Wire = Green, +, Fuse Box
Parking Brake = Yellow, -, Fuse Box
Horn = Black, -, By Ignition Harness
Speed Sense = Purple, Fuse Box
LF Window up/dn = Red / Green, Driver Door
RF Window up/dn = White / Pink, Driver Kick
LR Window up/dn = Yellow / Black, Driver Kick
RR Window up/dn = Red / Green, Driver Kick
Bones is offline   Reply With Quote
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Radio Install Harness and Kit redbluff In Car Entertainment + Electronics (audio / video / alarm) 16 08-06-2009 02:40 AM
Does anybody knows how to install the fog lights for the yaris hatchback? cburac DIY / Maintenance / Service 4 05-01-2006 12:51 AM
