Old 04-26-2017, 06:57 AM   #1
Pinchlite
Drives: 2007 yaris HB
Door handle reatachment..
I removed and painted passenger side door handle.I put back together using this guide...
http://www.yarisworld.com/forums/showthread.php?t=5792
The star screw is tightened down but when I pull handle the mechanism does not engage,it is just loose...http://i.imgur.com/lMjQS9F.jpg
It appears same location as what the drivers side is.Just looking for suggestions from anyone who has removed handles.
Thanks again.
UPDATE:sort of..
By the looks of this video the panel needs to be removed and there is a bolt @ 2:37 mark
https://www.youtube.com/watch?v=s_AiJkjqSpU
I will remove panel this weekend to see whats going on.Perhaps removing handle is the easy part but putting back on is another.
The link above who posted here may have not explained the entirety of the process.
Pinchlite is offline   Reply With Quote
Old 08-30-2020, 01:38 PM   #2
yangluchan
Drives: Yaris 2007
I did the same thing
the mechanisms did not engage
yangluchan is offline   Reply With Quote
Old 09-11-2020, 05:26 AM   #3
yangluchan
Drives: Yaris 2007
I fixed
When I took the car handles off
The mechanism for car outer door did work
I had to open up inner door trim then reach inside with my hands
And push grey lever down
U simultaneously hold the rod that attaches to yellow
When hold on rod
the grey lever stay in place
U then put in outer door handle inside
There by outer door handle gets hook onto grey lever
U check by pulling handles and Outer door handle spring back
If does not spring back
U got pull grey lever more
This is for 2007 Yaris
