Old 04-27-2017, 12:44 PM   #1
SteveKran
Drives: 2012 Yaris
Need help with 2012 cruise control install
I've got the cruise control installed, but I can't get the connector for the horn removed from the wire harness.
It's the blue wire. I've got the cover to the plug off and the wire isn't sliding out.
Any help would be appreciated!
I'm about to drive this car 700 miles home without a horn if I have to. The cruise does work, I just don't have a working horn.
Thank you!!!
Sent from my SM-G900V using Tapatalk
SteveKran is offline   Reply With Quote
Old 04-27-2017, 01:54 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The spade connector? There's a little retention tab that has to be depressed to get it to slide off.
Old 04-28-2017, 01:05 PM   #3
SteveKran
Drives: 2012 Yaris
Thanks, but I got the spade connector. That was a piece of cake. It was the other connector that had me stuck. I ended up carefully dissecting the white plastic connector with a fresh utility knife blade. Made quick work of it, and it slid out with no problem. Popped right into the cruise control connector and works like a champ. Thanks again!
Yaris Cruise Control NEW unused - $65 shipped NW Yaris Items for Sale by private party 3 04-24-2017 11:23 AM
2008 Yaris Cruise Control bassmannate DIY / Maintenance / Service 2 08-02-2016 02:46 PM
Yaris Cruise Control Auto evarkey Performance Modifications 1 07-02-2014 07:56 AM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
