Old 05-02-2017, 03:20 PM   #1
Shorter driver's side cv axle
This may be a long shot but does anyone know of a CV axle that will fit the Yaris trans and hubs (correct side splines) but is slightly shorter for the drivers side (left) axle?
For some reason my 2zr being wider pushed the trans closer to the drivers side and it's maxing out the cv axles compression. It still drives fine with some modification to engine mounts, but I'm curious to know if anyone is aware of a slightly shorter axle.
From reading other posts it is my understanding that the Scion xd axle is slightly longer so that it a no.
Old 05-02-2017, 03:32 PM   #2
Jason@SportsCar
How much do you need to shorten it? Best option might be to remove the CVs and have a machine shop shorten the center shaft, and then cut new splines.
Old 05-02-2017, 03:38 PM   #3
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
I don't know of any axles but I do have a question for you, skimmed through your build thread and I saw that you used both left and right xD engine mounts. I know Armstrong only used one of the xD mounts in his swap, just curious if this is why you have compression on the driver's side axle. Don't recall seeing Armstrong say anything about axle issues in any of his threads. Just curious.
heeroyuy01195 is offline   Reply With Quote
O.E.M. drivers side seat 2010 3 door. Drama Willing to Buy by private party 0 11-15-2014 10:05 PM
DIY: Yaris 2012+: driver's side "useless storage space" as phone holder spammerhamster DIY / Maintenance / Service 0 04-26-2014 06:15 PM
Drivers side window switch mellowdd Southwest 1 03-31-2014 09:27 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 03:16 AM
WTB Drivers side door for 3 dr liftback YaYa1320 Willing to Buy by private party 1 07-05-2009 01:48 AM
