Old 05-20-2017, 07:10 PM   #1
Yaris709
Drives: 07 yaris
Can't get new drums to go over new shoes?
Went to put new brake drums and shoes on my yaris today and when I got the new shoes installed he drums won't go back on and the adjuster is all the way in. The parts are identical to the old parts. What am I doing wrong? How do I go about fixing this issue?
Yaris709 is offline   Reply With Quote
Old 05-20-2017, 09:35 PM   #2
ex-x-fire
Make sure the wheel cylinders aren't frozen, carefully push each piston in, as you do this the other piston should move out. If it does that, then they should be ok.
Are there different size shoes? If so, the big ones go on the back.
Parking brake stuck on?
Sometimes you have to move the shoes up or down a little to get them on the center so the drum will slide on.
Old 05-21-2017, 03:58 AM   #3
Jamie101
Drives: Yaris 2002 1.0
Have you ground the lip off the drum before you try refitting. I always do this to make sure the drum has a good start at sliding onto the shoes. And dubble check all the adjustment is off of your handbrake cable and that the cable moves freely on both sides as these can seize up. Also like the other member said in the previous reply have you compared the shoes your new ones to the old ones. There are so many little differences with these cars!
Jamie101 is offline   Reply With Quote
Old 05-21-2017, 05:59 AM   #4
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Are your handbrake cables loose enough ?
Send from OnePlus 3T
KimmoKekki is offline   Reply With Quote
Old 05-21-2017, 10:01 AM   #5
Yaris709
Drives: 07 yaris
Haven't thought of the handbrake cable. I tightened it up a bit up under the center console about 6 months ago. Would this be causing any problems? And my wheel cylinders are free btw and the parts are 100% identical other than old parts worn out.
Old 05-21-2017, 11:45 AM   #6
ex-x-fire
We'll need some good pictures if you haven't figured it out yet.
Old 05-21-2017, 01:26 PM   #7
Yaris709
Drives: 07 yaris
Just slacked off the handbrake cable and everything is fitting better I'm moving around the shoes now trying to get it to fit. I can get one side on but not the other
Old 05-21-2017, 01:39 PM   #8
Just putting this out there. Since you were able to slide one drum on after slacking handbrake but not the other, then the cable may be seized on the one side.
Old 05-21-2017, 07:53 PM   #9
Yaris709
Drives: 07 yaris
So guys I feel kinda stupid haha I had a toyota mechanic come by and help me. Turns out that the shoes are different than the old ones! Compared side by side the new ones were about a 1/4 inch longer than the old shoes which is why they wouldn't fit. All the holes and mounts look exactly the same but longer shoes. Is there different shoes for differnt model yaris's?
Old 05-22-2017, 02:40 AM   #10
Jamie101
Dont worry about it mate we all drop clangers like that now and again we just dont say anything! At least u admited it! Haha. As i said on my previous post to you there are loads of different bits on these cars that are different just note it down next time you wanna buy anything for the yaris - dubble and tripple check parts with your old ones! Glad you got it sorted in the end mate!
Old 05-22-2017, 12:50 PM   #11
zoidberg444
zoidberg444's Avatar
You know I was looking on one of the parts places for brake parts for my sisters Yaris and I'm sure there were at least 2 different options as far as drums and shoes go. I think there are 3 different options for front discs and pads. I just measured the old ones to find the right brake hardware for mine.
In the UK we had French and Jap Yaris's and various engine sizes so its no wonder we had different brake options.
UK to Nordkapp in a Yaris
Old 05-23-2017, 08:51 AM   #12
Yaris709
Drives: 07 yaris
One more problem now guys. I had to replace a few wheel studs because previous garage impacted my lug nuts on VERY tight. Twist off 3 of 4 on one side. Can't get the new lugs to go in straight. What do I do now?
Old 05-23-2017, 09:36 AM   #13
zoidberg444
They are supposed to be in there very tight, you just need to get them started. If you can't the only thing i can think of is pulling the assembly off the car and taking them somewhere to get installed or getting a used hub/knuckle with studs from a scrap yard.
Sent from my SM-G900F using Tapatalk
Old 05-23-2017, 09:52 AM   #14
Using a lug nut, conical side out, to draw them in tight they should self align.
Old 05-23-2017, 10:04 AM   #15
zoidberg444
You know i never thought of that. Certainly sounds easier than bashing them with a hammer and a case of crushed fingers. 😂
Old 05-24-2017, 08:57 PM   #16
Yaris709
Drives: 07 yaris
Only had lug nuts with the closed end but used a couple washers to keep the lug nut straight and used a ratchet to tighten them in. All studs straight and seated in perfect!
Old 05-24-2017, 08:59 PM   #17
Yaris709
Drives: 07 yaris
Now how do I adjust the rear brakes properly? Tighten them till I can't move the drum by hand and back them off 2-3 turns?
air suspension thread jerome Wheels, Tires and Suspension Forum sponsored by The Tire Rack 93 09-23-2017 01:34 PM
spark plug change tools patm DIY / Maintenance / Service 1 10-17-2011 04:42 PM
