Old 05-21-2017, 08:49 AM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
Engine heating like hell !!!!
i've oem rad.....synthetic coolant....the car is not over heating....but heat comes inside the cabin....and engine heats up like hell.....need advice. Do i need to change the water pump.....or buy a bigger radiator.....or do nothing
Bony_ahmed is offline   Reply With Quote
Old 05-21-2017, 09:28 AM   #2
Make sure you're using the proper red coolant.
And make sure your heater controls aren't broken. If the cable came off it could be stuck at full heat.
Old 05-21-2017, 09:41 AM   #3
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
I've never really noticed heat coming inside the cabin, except when driving at full throttle on the autobahn. I'm not sure, but i think the headers of every single engine available for the Yaris are facing towards the cars firewall. So the headers could cause your cabin to heat up quite a lot. So maybe a exhaust heat wrap can cope with that.
But if you are not driving at full throttle and heat still comes inside your cabin, that would mean that most likely something is wrong with your cooling system.
DiCaprio is offline   Reply With Quote
Old 05-21-2017, 01:20 PM   #4
SirDigby
Drives: 2007 yaris 3 door
DEI also makes a product called Reflect-A-Gold that is adhesive 18k gold you can stick to your firewall and cover your ECU. awesome product for blocking radiant heat. also hood vents remove heat as well.
Old 05-21-2017, 07:38 PM   #5
jra
Drives: 2015 yaris L
Could be hot water valve to your heater core letting water circulate, valve not closed all the way, or a bad valve, I've had heater valves that were closed but would still let water through. Touch your heater hoses at the firewall, if both hoses are hot, it's the heater valve.
jra is offline   Reply With Quote
Old 05-21-2017, 08:27 PM   #6
I thought there is always coolant flow to the hear exchanger, it is just the air flowbtjat changes to include or exclude the hear or cold outside air?
Old 05-22-2017, 03:50 PM   #7
Bony_ahmed
i've checked everything......no problems anywhere....thinking about adding an external fan to improve cooling......r there any drawbacks to that ?
Japanese engine into French Yaris 1.0 2002 Jamie101 DIY / Maintenance / Service 5 02-12-2018 10:41 AM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
