Old 05-29-2017, 08:57 PM   #1
truefusion
Drives: Toyota Yaris LE 2013
Diagnosing codes P0441 and P0455
I have a 2013 Yaris and it has a check engine light and it is returning a couple of codes (P0441 and P0455), and I would like to try and diagnose the problem, starting at the canister purge valve, but I am having trouble locating it.
Sent from my VS986 using Tapatalk
truefusion is offline   Reply With Quote
Old 05-30-2017, 12:39 PM   #2
bronsin
bronsin's Avatar
PO441 evap emission control system incorrect purge flow.
Have you checked the gas cap?
Old 05-30-2017, 01:06 PM   #3
P0455 is a code for a leak but I've only seen one of the codes for a small leak thrown by an improperly sealed gas cap. Not a code for a large or gross leak like the P0455 is, unless the gas cap is not even on.
Old 05-30-2017, 08:17 PM   #4
truefusion
... unless the gas cap is not even on.
I jiggled the cap and it basically fell into my hand. I must've not tighened it the last time I pumped gas. I will reset the codes and consider this to be the reason (unless it comes back on), though I am still interested in some kind of diagram of my engine and surrounding area.
Old 05-31-2017, 04:30 AM   #5
bronsin
bronsin's Avatar
Car is pretty new to something besides the cap
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
