Old 05-30-2017, 04:37 AM   #1
Reydan
Drives: 2011 yaris
Suspension issue
Hi, I have suspension issue with my 2011 yaris. Hope somebody could help. I can hear *tok tok* sound whenever i ran oven humps at moderate speed. TIA
Reydan is offline   Reply With Quote
Old 05-30-2017, 07:03 AM   #2
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
You better go to a local shop to get your suspension inspected if you can't do it yourself.
Also it's not really possible for me to find the issue without looking at it.
One thing check if you can see oil leaking from your coilovers, if so they are probably toast.
curious what the other think
DiCaprio is offline   Reply With Quote
Old 05-30-2017, 07:58 AM   #3
with that vague of info there is nothing we can do. Inspect the suspension yourself and if you don't know how to do that then take it to a shop to inspect for you. Simply stating that your suspension is making noise doesn't really mean much without you looking at it to inspect it. Almost all suspensions parts will make noise over bumps when they start to fail
Old 05-30-2017, 09:25 AM   #4
simple things to check are ball joints an the sway bar end links.
Old 06-01-2017, 09:37 PM   #5
jra
Drives: 2015 yaris L
My guess would be the sway bar links.
jra is offline   Reply With Quote
Old 06-01-2017, 10:32 PM   #6
SirDigby
Drives: 2007 yaris 3 door
he means struts and shocks, as coils are your springs and do not contain oil...
Old 06-02-2017, 02:26 PM   #7
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Correct i mean the shocks obviously springs don't contain oil :D
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Mystery Suspension issue Please help! Yaris79 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 04-12-2011 10:50 PM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
