Old 06-06-2017, 12:17 AM   #1
mell0n
Drives: 2008 Yaris Sedan
2008 Yaris Sedan Airbag Light DTC Code 55
After learning how to check the DTC using the guide by CTScott, the vehicle indicated code "55". I took a look at the repair manual and it seems to indicate several generic faults with the driver's curtain bag?
I'm just curious if anyone has dealt with this issue, I'm starting to think it could be the SRS module/sensor as the light has also been intermittent although recently it has stayed on.
mell0n is offline   Reply With Quote
Old 06-06-2017, 07:17 AM   #2
Has the vehicle had the recall for drivers side spiral cable performed?
Old 06-07-2017, 12:45 AM   #3
mell0n
Yes, the clockspring has been replaced.
Old 06-12-2017, 09:08 PM   #4
mell0n
Update: light continues to be intermittent I disassembled the console to get the part number for the center airbag module and just unplugged and replugged the large connector going to the box. Probably not going to fix it, but I figured it was worth a shot.
Airbag light on 2007 yaris sedan . Thoughts on things to check? 5ABIVT DIY / Maintenance / Service 5 04-06-2015 11:42 PM
Nevermind Need To Delete this Post LEXX DIY / Maintenance / Service 2 10-01-2011 02:40 AM
