Old 06-13-2017, 09:03 AM   #1
ACKING_QC
Drives: 2018 VW TSi Stage1
C60 6 speed questionS
AY! I just want some infos about the C60 6-speed transmission.... I know that with a bit of cutting, it fits the 1NZ just fine, but someone made me doubt about a thing or two...
first of all... are they all 6 speed LSD? a friend of mine bought a C60 from a Vibe GT and the guy who had it, said it was a LSD transmission .... I'm a bit skeptical about that...
second thing, will there be any improvements in my driving for swapping to a C60? (MPG or km/L ... because Canada... , etc...)
and finally third, is it really worth it ?
ACKING_QC is offline   Reply With Quote
Old 06-13-2017, 09:45 AM   #2
You don't want a C60, you want a C160. And you need to swap the bell housing from your stock transmission. The C60 uses bigger axles and not all C60s are LSD.
Old 06-13-2017, 11:20 AM   #3
What cars were the C160 found in? Also, is it a direct bolt on or is there some internals that need switching?
Old 06-13-2017, 11:26 AM   #4
Nvm, just searched your trans swap thread. Due to the 2zr being much wider I doubt the 6spd trans would fit without serious alterations to the frame rail.
Old 06-13-2017, 03:26 PM   #5
ACKING_QC
C60 or C160 there is the question ...
Old 06-13-2017, 03:36 PM   #6
They have the same gearing except the C160 will accept the stock axles.
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 306 08-02-2026 02:50 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
