Old 06-23-2017, 05:59 PM   #1
funky2nite
Drives: 2013 Hybrid 1.5L T4
Lightbulb Battery question - jump starting and hooking up new accesories
So first question goes:
Since hybrid has both the main 12V battery plus the hybrid batteries hidden together under rear seat, should the main battery go defective/needing replacement, is the car still capable to withdraw from the hybrid batteries to still start up the engine and run?
Irrespective if the above question is answered yes or not, can the main battery still be jump atarted using conventionl jump leads method, obviously running the cables to the rear aeat instead the bonnet and the kther ends to the donor car's bonnet?
With regards to accesories, an epic fail is the third gen yaris without a centre dome light, only one in the front above the head unit, we have a young son which is lways throwing toys around and that dome light is the only hope of finding stuff around, so ill be fitting a universal one and im also planning to fit a roof mount screen that flips open. With all the hype about hybrid high voltage etc, where would one suggest to source power from for both accesories or anything else requiring 12v?
funky2nite is offline   Reply With Quote
