Old 07-07-2017, 01:57 PM   #1
rafhelp
Drives: Toyota Yaris 1.33 TR
cool warning light
hi,
last few days noticed the COOL light (greenish light) on the the dash display shows up when i start the car. After a few minutes the light goes out.
I read this is no big deal just tells you engine is cool. BUT here its summer time it should not really be that cold wonder what will happen in winter?
also noticed when setting off car seems bit jumpy, not getting as good a response from gas pedal but again after the cool light goes off this problem also seems to go.
ps. is there anything i can do to increase the 'kick' well without expensive engine modifications?
rafhelp is offline   Reply With Quote
Old 07-07-2017, 02:47 PM   #2
Rigaud
Drives: 2009 Yaris
Originally Posted by rafhelp View Post
hi,
It stay`s on below 55c engine temp. All of them do this and unless it`s above 55c outside......... ;)
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-07-2017, 03:27 PM   #3
Anything you can do? Not really. Programming keeps the engine/tranny (if automatic) in a somewhat 'retarded' state until the engine warms enough to deactivate the light.
Old 07-09-2017, 06:35 AM   #4
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
yeah it also determines when we hit 4th for the auto tranny peoples
Old 07-09-2017, 09:07 AM   #5
MadMax
MadMax's Avatar
hi,
I live in southcentral Texas and still get the green light for the first mile or so during the summer. It's there for a good reason and will help your car last longer, and as it only lasts a few minutes it really isn't an inconvenience.
Patience is a virtue, y'know!
Old 07-09-2017, 01:26 PM   #6
Yaris709
Drives: 07 yaris
Any cars temperature will be low when first starting up after sitting for a period of time. There's nothing you can do about it. It's completely normal for this to happen. In winter it just takes a little longer to warm up.
Yaris709 is offline   Reply With Quote
Old 07-09-2017, 02:56 PM   #7
David C
Drives: White '07 3dr LB
The cheapest and easiest mod you can do is installing a block heater ($30~$50) and run it on a timer to activate 2-3 hours before your usual commute. If you don't work a fixed schedule (like me), then it's not always gonna help unless you leave it on 24/7 so it's always warm for when you need to roll out.
David C is offline   Reply With Quote
Old 07-09-2017, 03:54 PM   #8
ACKING_QC
Drives: 2018 VW TSi Stage1
I was hoping for a picture of weird warning lights.. or a meme... I am disapointed
ACKING_QC is offline   Reply With Quote
Old 07-15-2017, 07:18 PM   #9
rafhelp
ok i only asked as when i bought for first few days this light never came on
Old 07-15-2017, 11:39 PM   #10
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
That makes no sense. it should always come on and stay on for the first few minutes.
Sent from my phone. Please excuse any typpos.
Old 07-16-2017, 01:10 AM   #11
scylla
Drives: 2015 Yaris L
Maybe he was like me. I didn't notice the light was on at startup for the first couple of times I drove it. Probably was too busy getting my seat just right and my all important tunes loaded.
Kinda freaked me out at first. I thought it was a over temp light until I finally looked through the owners manual.
scylla is offline   Reply With Quote
Old 07-24-2017, 05:57 AM   #12
rafhelp
ok myabe you are right..
but what about the non responsive gas pedal, when cool light is on. going up hill pressing gas and doesnt seem to move, very sluggish even if flooring the pedal. its not like clutch where you get lots of revs and no movement..the revs dont go up. its like it doesnt want to go and you really have to push it
Old 07-24-2017, 07:05 AM   #13
sickpuppy1
Wait till winter gets here, you'll really hate it! lol
Old 07-24-2017, 08:33 AM   #14
David C
The car doesn't want you to rev up the engine until the oil and cylinder walls are warm enough to get properly lubed, aka preventing you from wearing out your engine on cold starts. Let the engine run for a few seconds after startup before taking off, usually till the revs drop from 2k to 1.5k. Maybe 10 seconds in summer and 30 seconds in winter. Don't let it idle longer than necessary and drive it gently, without going above 2500 rpm/40km/h. That'll give you the best results. Also try to keep the electrical load on the alternator as low as possible until warm, as not to put additional drag on the engine.
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
Yaris 2001 The engine yellow/orange warning light in the dashboard cabbage2001 DIY / Maintenance / Service 11 01-16-2015 06:53 AM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
windshield warning light...? yaris user5Mottyl General Yaris / Vitz Discussion 1 05-31-2012 10:23 PM
Explination point(?) warning light... dodgerblu88 DIY / Maintenance / Service 1 03-04-2012 07:18 AM
