Old 07-24-2017, 11:02 AM   #1
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Damage on tire! Is it still save to use?
Hey guys,
so unfortunately i lent my car yesterday and the person i lent it to damaged one rim and the tire. Ok cool the rims are easily repairable i probably don't need to buy a new rim, but i'm curious about the tire. I don't know much about tires, so for me it looks like a small mark, but i mean at the same time a small mark can possibly also be a huge risk. What do you think? I post the pictures below
DiCaprio is offline   Reply With Quote
Old 07-24-2017, 12:06 PM   #2
Cezza07
Drives: 2014 Toyota Yaris L
IT's on the sidewall. I would probably look at getting it changed, and avoid going over 40.
But I'm an aircraft mechanic and which makes me a little more safety conscious.
That's my thoughts, at least.
2014 Toyota Yaris L
Cezza07 is offline   Reply With Quote
Old 07-24-2017, 12:06 PM   #3
That's no issue.
Old 07-24-2017, 12:35 PM   #4
DiCaprio
Just a Gaijin
DiCaprio's Avatar
I'd go to a local tire shop and let them have a look at it, but of course they just want to sell me 2 new tires anyways, since you always need to change a set of two per axis.
Old 07-24-2017, 12:55 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
It's a small, very shallow gouge in the sidewall. Plus, it's located on the thicker rubber molded rim protector. It's nothing to worry about at all.
Old 07-24-2017, 05:23 PM   #6
B.B._07
Drives: 07 5dr
The damage is only cosmetic, tire manufacturer's put the extra thickness in the sidewall of low profile tires right next to the rim to minimize curb rash on your rims.
Old 07-24-2017, 10:03 PM   #7
Yaris709
Drives: 07 yaris
There's steel belts under there as long as they aren't torn up your good to go. And they're definitely not torn with that little gouge. I'd be more upset about the scrapes on the rim if it was me
Yaris709 is offline   Reply With Quote
Question on Wheel and Tire soup1207 DIY / Maintenance / Service 1 05-24-2013 11:11 AM
high mileage highway tire for SE adio51 Third Gen Yaris General Discussion 2 12-08-2012 01:00 PM
Tire Wear Analysis Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-13-2009 10:28 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 10:44 AM
Save up to $40 - TWM Spring Sale! TWM Performance Sponsors Classifieds Area 0 04-03-2007 04:04 PM
