Old 07-31-2017, 12:03 AM   #1
Frank Necrosis
Drives: 2012 Yaris L MT
Water leak
Took my 2012 through the car wash. There was a fair amount of water running down the inside of the back window. There are other mater marks from other leaks.
I am fairly sure the leak is coming from the center brake light. The inner cover was wet and quite dirty when I removed it.
How does the brake light come out? Looks like 2 clips hold it in. Is there supposed to be a gasket between the light and hatch?
Frank Necrosis is offline   Reply With Quote
Old 08-14-2017, 04:14 PM   #2
Frank Necrosis
Follow up.
The third brake light pops out fairly easy. Just squeeze the large metal clips that wrap round the back side of the light. Squeeze them as close to the sheet metal as possible.
Once removed, the original gasket was completely destroyed. It was hard as a rock, smashed flat and full of cracks. I peeled it off, liberal amounts of goo gone were required to get the backing tape off.
Once all was cleaned up, I made a new gasket using household foam weather stripping. Had to some trimming here and there, but it is not leaking anymore.
2008 toyota yaris 2 door hatchback water leak knobby bobby DIY / Maintenance / Service 8 07-03-2024 07:42 AM
Water leak to passenger side AND driver side TMR3 DIY / Maintenance / Service 7 05-21-2017 08:19 AM
Water leak problem Yaris874 General Yaris / Vitz Discussion 5 04-10-2017 01:03 PM
Water leak in Hatch ilikerice DIY / Maintenance / Service 40 10-22-2016 03:46 AM
Water Leak! Failed Relays cfeng DIY / Maintenance / Service 0 12-13-2010 06:21 AM
