Old 08-16-2017, 03:36 PM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Quantum Technology Hydrogen 1NZ Turbo Kit GT1241
I purchased and mocked up this kit on my 1NZ but never got it installed.
$1000.
Here are all the additional parts I purchased for the kit.
10AN Universal Steel Oil Pan Return Drain Plug Adapter Bung Fitting Weldable
4pc -10 AN Fitting Straight Black Swivel
(4) 2" to 2" Black 45 Degree Elbow Silicone Hose Coupler
90 Degree Swivel 4AN Male to Female Fitting Adapter
10AN 45 Degree black Swivel Fuel Oil Air Gas Hose End Fitting Adapter
Universal Polished 2'' 51mm Aluminum Intercooler Pipe Kit
Denso Flow Matched Fuel Injector Set for Toyota-Pontiac 1.8 23250-22080 (4)
(2) 1.75-2"3-PLY UNIVERSAL TURBO/INTAKE PIPING CONNECTOR COUPLER SILICONE HOSE BLACK
(3) 1.5" TO 2" 3-PLY UNIVERSAL STRAIGHT COUPLER REDUCER PIPING SILICONE HOSE BLACK'
2" 50mm straight Flange Pipe+ ADJUSTABLE SSQV SQV Blow Off Valve BOV II 2 BLACK
4AN Male Flare To 1/8" NPT Pipe Thread Straight Black Aluminum
(1) 1.75"-2"90 DEGREE REDUCER 4-PLY BLACK SILICONE HOSE INTAKE/INTERCOOLER COUPLER
2" Black AN10 Nylon And Stainless Steel Braided Fuel Oil Gas Line Hose -10AN
(2) AN10 45 Degree Swivel Oil Fuel Line Hose End Fitting
Turbo Oil Pan / Oil Return Drain Plug Adapter Bung Fitting 10AN no Weld 90DEG
Black -8 Female -10 Male AN Flare Fitting Expander Adapter 8AN to 10AN
(4) 2" 3-PLY STRAIGHT TURBO/INTAKE PIPING SILICONE COUPLER REDUCER HOSE/PIPE RED
1/8 NPT Hex Head Pipe Plug Fitting Black
2" 52MM PSI Digital Boost Vacuum Gauge Meter Car LED Red & Blue Universal
2"52 mm Digital LED Car Oil Pressure Meter Gauge Red Blue l
4AN to 1/8'' NPT Straight Adapter Pipe Fuel Oil Air Fitting Black Color
Turbo Water Feed & Return Line Kit Garrett GT12 GT1241
Turbo Oil Feed & Return Flange Garrett GT12 GT1241 4AN Feed / 8AN Return
1/8" BSPT Oil Pressure Sensor Fitting
UNIVERSAL 36" STEEL OIL FEED LINE KIT 1/8 NPT
I'll post more pictures later today.
JustDidIt is offline   Reply With Quote
Old 02-16-2018, 07:43 AM   #2
JustDidIt
JustDidIt's Avatar
Reduced! $1000. Bump!
Old 02-16-2018, 09:26 AM   #3
That manifold looks very efficient. But isn't that a super tiny turbo!!
Old 02-16-2018, 09:29 AM   #4
JustDidIt
JustDidIt's Avatar
It is small. It was used to boost the 1NZ after swapping out the gasoline components of the engine for hydrogen. The power loss from hydrogen required the company to boost the engine to make up for lost power.
Old 02-17-2018, 03:07 PM   #5
JustDidIt
JustDidIt's Avatar
Posted it locally on Craigslist also. 1nz 1nzfe 1nz-fe 1nzfxe 1nz-fxe 1nz-fte 1nz-fet turbo kit. :)
https://dallas.craigslist.org/dal/pt...500245938.html
Old 02-22-2018, 07:44 AM   #6
Whiplash
Drives: 2009 Yaris 4DR
I love the idea of this, but how complete is it?
Whiplash is offline   Reply With Quote
Old 02-22-2018, 09:56 AM   #7
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
holy crap you're in the dfw?!
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 02-22-2018, 10:32 AM   #8
JustDidIt
JustDidIt's Avatar
I bought the used kit to fit a 1NZ-FXE but wanted to change the intake routing and purchased a 2” intercooler piping kit so I could custom route the intake charge. Kits usually don’t come with colder plugs and larger flow injectors, but in my kit they are. The only thing still needed is some sort of piggyback. Camcon, AEM FIC or Greddy eManage Ultimate (Which I also have for sale $350)
Yup. Moved here about a year and a half ago.
Old 02-22-2018, 10:40 AM   #9
JustDidIt
JustDidIt's Avatar
The original post was cluttered so i re-worded it.
Included with this kit:
* Garrett Turbo - GT1241 from hydrogen turbo kit
* Fabricated exhaust manifold - Hydrogen Turbo Kit
* Down pipe flange to be welded to stock exhaust
* Fabricated intake and intercooler plumbing - 2 inch and 1.75 inch mandrel bent - Hydrogen Turbo Kit
* One heat range colder Iridium spark plugs - NGK 2667
* Intercooler - Hydrogen Turbo Kit came with a Spearco
* 2" Airflow MAF adapter needs to be welded to intake piping
* eBay HKS blow-off valve (2" 50mm straight Flange Pipe adjustable SSQV SQV BOV BLACK
* 1ZZ-FE injectors for 30% more fuel flow (Denso Flow Matched Fuel Injector Set for Toyota-Pontiac 1.8 23250-22080 (4))
* 10AN Universal Steel Oil Pan Return Drain Plug Adapter Bung Fitting Weldable
* 4pc -10 AN Fitting Straight Black Swivel
* (4) 2" to 2" Black 45 Degree Elbow Silicone Hose Coupler
* 90 Degree Swivel 4AN Male to Female Fitting Adapter
* 10AN 45 Degree black Swivel Fuel Oil Air Gas Hose End Fitting Adapter
* 4AN Male Flare To 1/8" NPT Pipe Thread Straight Black Aluminum
* (2) Black AN10 Nylon And Stainless Steel Braided Fuel Oil Gas Line Hose -10AN
* (2) AN10 45 Degree Swivel Oil Fuel Line Hose End Fitting
* 10AN 90 degreeTurbo Oil Pan / Oil Return Drain Plug Adapter Bung Fitting no Weld
* Black 8AN Female to 10AN Male Flare Fitting Expander Adapter 8AN to 10AN
* 1/8 NPT Hex Head Pipe Plug Fitting Black
* 4AN to 1/8'' NPT Straight Adapter Pipe Fuel Oil Air Fitting Black Color
* 1/8" BSPT Oil Pressure Sensor Fitting
* Universal Polished 2'' 51mm Aluminum Intercooler Pipe Kit
* (2) 1.75-2" 3-PLY universal reducer turbo/intake piping connector black silcone coupler
* (3) 1.5" TO 2" 3-PLY universal straight turbo/intake piping connector black silcone coupler
* (1) 1.75"-2" 90 degree reducer 4-PLY straight turbo/intake piping connector black silcone coupler
* (4) 2" 3-PLY straight turbo/intake piping connector red silcone coupler
* 2" 52mm PSI Universal Digital Boost Vacuum Gauge Meter Car LED Red & Blue
* 2" 52mm Universal Digital LED Car Oil Pressure Meter Gauge Red & Blue
* Turbo Water Feed & Return Line Kit Garrett GT12 GT1241
* Turbo Oil Feed & Return Flange Garrett GT12 GT1241 4AN Feed / 8AN Return
* Universal 36" steel oil feed linke kit 1/8 NPT
1NZ-FXE Engine from pictures is also for sale for local pickup. $200
* Wrinkle red Valve cover
* Wrinkle red Intake manifold
* New piston ring ready for install
* New main bearings ready for install
* DAMAGE: Upper oil pan ($50?) will need to be replaced because of hole from drive shaft.
Greddy eManage Ultimate ($350)
Old 02-23-2018, 06:08 AM   #10
Whiplash
I see you also have it on ebay. Please keep me in mind if you are having trouble selling his. Like I said, I like the idea, but for me its priced high (I think your price is fair, I'm just poor).
I''ll add it to ebay watch list. Cheers and good luck.
Old 02-23-2018, 09:13 AM   #11
Just an FYI for everyone... the fitting in the block where the oil feed is being tapped is a BPT fitting NOT NPT. It will damage the threads if you try and ram a NPT fitting in there.
Old 02-23-2018, 06:22 PM   #12
JustDidIt
JustDidIt's Avatar
Yup, mine includes a BPT to NPT adaptor fitting.
Originally Posted by Shonuup
* 1/8" BSPT Oil Pressure Sensor Fitting (Each adapter has (1) 1/8" BSPT male, (2) 1/8" NPT female, (1) 1/8" BSPT female ports. The 1/8" BSPT male will be installed back into your factory oil pressure location. The 1/8" BSPT Female port at the end lets you install your factory oil pressure gauge back in.)
Old 08-08-2018, 11:17 AM   #13
JustDidIt
JustDidIt's Avatar
Bump! This is still available.
Turbo Kit: $1150
  • Shipped to anywhere in the USA.
Turbo Kit: $1350
  • Including Greddy eManage Ultimate
Old 08-31-2018, 03:07 PM   #14
JustDidIt
JustDidIt's Avatar
SOLD! please lock thread.
WTB Turbo kit ynnek317 Willing to Buy by private party 5 07-04-2014 01:53 PM
For Sale: ZPI Turbo Kit CTScott Items for Sale by private party 27 12-10-2013 06:00 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
