Old 08-17-2017, 08:19 PM   #1
09GLH
Drives: 2009 Yaris 5 door
That was a fun ride home
Started surging, then dropped out of 4th into 3rd, and slammed back up into 4th. Over and over. Off to AAMCO for a new solenoid.
https://www.youtube.com/watch?v=nSz16ngdsG0
09GLH is offline   Reply With Quote
Old 08-19-2017, 12:15 PM   #2
09GLH
Just got a call from AAMCO, and they told me the following. The speed sensor is fine, and is supplying the correct input to the speedometer. From there it sends a signal to the ECM, which controls the shift solenoids. It's losing voltage from the cluster to the ECM, and the car thinks I'm doing 35 mph when the speedometer reads 70. They said the transmission is perfectly fine otherwise.
Has anyone had this happen?! This thing is my daily and I have a 150+ mile daily commute. Just buy another cluster and have a dealer reflash my keys??
Old 10-26-2017, 11:39 PM   #3
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
manual or auto the age old question?
This is why i prefer a manual stick shift gear box
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
Old 10-27-2017, 02:12 AM   #4
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Like clutches, etc. don't fail before 218K miles...
Kalispel is offline   Reply With Quote
Old 03-01-2019, 01:06 AM   #5
09GLH
It was a bad ground bolt. The factory location was corroded almost all the way through, maybe 1/16" left. I welded in a patch panel and it fixed it right up. So it wasn't a communication between body computers, sensors, or anything else dealerships and transmission shops recommended.
Old 03-01-2019, 09:11 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Wow, a year and a half with that problem? Ouch! =D
