Old 08-25-2017, 03:12 PM   #1
duendeverde
Drives: Yaris 2010 Manual
Header Installation
Has anyone notice a plastic burned smell after installing a header. I just bought a header from Amazon and after installing it drove a couple of miles (10-15 miles to be exact) I notice the smell.
I couldn't see any cables touching the headers. I re-routed the O2 sensor cable as far from the header but still the smell persist. Is the smell normal. I have read in some forums that the smell is due to the header itself
Thanks!!!
duendeverde is offline   Reply With Quote
Old 08-26-2017, 10:09 PM   #2
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Over the first day or two it will burn off the oils/grease from the install and manufacturing. I don't know that I would describe it as a burning plastic smell though
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 08-27-2017, 05:30 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
header makes burning smell
My exhaust parts always come w/ well stuck factory, warehouse and shipping labels. Wouldn't be surprised if some sort of anti-rust finish is on the header to keep it looking new until installed.
Old 08-27-2017, 07:09 AM   #4
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Almost all metal car parts come with some kind of anti rush protection layer. Break discs have a pretty thick protection layer for example and that's why you should always use break cleaner when you install new breaks even if they don't look dirty.
DiCaprio is offline   Reply With Quote
Old 08-27-2017, 05:57 PM   #5
duendeverde
Ok. Ill wait a couple of days
Old 08-27-2017, 06:46 PM   #6
You probably also had some smoke in the engine bay too after the install you never noticed. Its normal due to the coating on the header so itndoesnt corrode in the factory. To drive it hard for a while and it will go away
Old 09-02-2017, 08:11 PM   #7
duendeverde
Update: No smell at all after local cruising, no more than 15-20 miles
Will go for longer cruising next week
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
Ceramic wrapping a header leoseller7 DIY / Maintenance / Service 2 04-21-2013 07:39 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
