Old 08-28-2017, 07:17 AM   #1
rabbito
rabbito's Avatar
Camshaft day (Pic)
Installed camshaft today...
duration 264, lift 9.5...same duration and lift as the jun regular series (none bolt on)..quality is fantastic without any machinery defects..
i didnt chose the 272 9.5 bolt on series? that runs with stock ecu because i have a piggyback already running my E85 250cc injectors etc..
i drove 15km to my house some how without getting tuned because the dyno and tuning place is opposite of my house..getting fully tuned on sunday, i will update soon...im losing power here and there throughout the rpm band because my air ratio and fuels not tuned yet(piggyback)..
i posted the camshaft seller on the screen capture(facebook) below...he speaks english and i think his exporting cams to other countries...
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 08-28-2017, 09:25 PM   #2
SirDigby
Drives: 2007 yaris 3 door
neat!
Old 08-28-2017, 11:28 PM   #3
Cool. And the work with the stock valvetrain?
Old 08-28-2017, 11:52 PM   #4
rabbito
rabbito's Avatar
my car can stay up to 7000rpm with stock valvetrain and spring..you need to change spring etc. when you pass 7000rpm..i dont have enough money to do that lol...valve and spring parts are pretty expensive..
Old 08-29-2017, 03:39 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I'm running stock springs with ti retainers to 8k and no float but I wouldn't go much higher than that and I don't suspect the springs will last all that long.
Cams are 236@.05 with .36" lift. Still makes power at 8k but the stock intake and TB have given up by that point.
2014 BSpec Divisional Champion
Old 08-30-2017, 10:38 AM   #6
rabbito
rabbito's Avatar
are you using piggyback or standalone? how much did you gain? im going to be on dyno and retune my ecu this saturday..
Old 08-30-2017, 02:08 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'm running a AEM series 2 that piggybacks off throttle, but is fully controlling cam\ignition\fuel.
Its hard to say how much I gained because it was a new motor with quite a bit of work done to match the rules for the class I race in. My peak power changed from 5.9k to 7k and stays flat until I shift at 8k but thats mostly due to running out of air from the intake man and tb.
Old 09-02-2017, 03:37 AM   #8
rabbito
rabbito's Avatar
writing dyno result and issue on new page
$105 Track day @ Willow Springs- Big Willow Dec 21st judd Tracking, Racing, Auto-X Forum 0 12-14-2013 11:50 PM
Memorial Day Weekend Meet/Picnic in Southbury, CT? CTScott New England 10 07-25-2013 11:47 PM
Nice day out..new Yaris pic detroiter Photo-Video-Media Gallery 2 03-18-2013 10:26 PM
Labor Day Weekend in Malibu/Rock Store (do people still have 56k?) AdeJong 03 Photo-Video-Media Gallery 15 09-09-2009 06:17 PM
