Old 08-28-2017, 11:31 PM   #1
FellFromGrace
Drives: 07 Yaris/90 Foxbody/05 Mini S
Unhappy Yaris has low power and won't start
Hey everyone, my names Christina and I'm new here.
My Yaris has been down for a while now... Been trying to figure it out, but haven't had any luck.
It's an 07' and manual.
The problem just kind of happened out of no where, so I can't give any information regarding symptoms it was having before the actual issue.... I can try and shed some light on what I'm experiencing now.
Woke up one morning, tried to start it. Nothing. It doesn't turn over. Tried jumping and changing batteries. Still nothing.
Some of the small dash lights like the Check Engine Light illuminate, but not the actual speedometer/clock etc.
The interior dome light is dim, and sometimes not even on.
No headlights. The very little dash lights that do illuminate cut out when I apply the brake and slowly come back on after I let off.
I checked all the fuses under the hood, all good. I even tried bypassing the clutch safety switch. Stilll nothing...
Even tried ODB, but it doesn't even seem to have enough power to do that.
Just keeps trying to connect.
I'm very lost...
FellFromGrace is offline   Reply With Quote
Old 08-29-2017, 12:09 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Definitely something electrical. Have you checked the fusible link on the positive battery cable? Are all the cables tight and free of corrosion?
Old 09-07-2017, 11:34 AM   #3
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
Happend to my Ford Mondeo ended up scrapping her never did work it out! hope you have better luck!
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
Old 09-11-2017, 02:50 AM   #4
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Try to jump start it pypassing the cars battery.
Prettty often a battery will fail and not allow power to flow through it.
Good luck
ncp13 is offline   Reply With Quote
