Old 08-30-2017, 07:49 AM   #1
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
Exhaust upgrade
Anyone upgraded their OEM muffler with a slightly larger one? If so what did you all noticed besides louder noise? Pics and brand will help me a lot as well. thx in advance.
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 08-30-2017, 09:55 AM   #2
ACKING_QC
Drives: 2018 VW TSi Stage1
if you want noises, replace the second cat, the resonator and the muffler by peices of pipe.. NOW this is noises LOL and way less restrictive too
ACKING_QC is offline   Reply With Quote
Old 08-30-2017, 10:29 AM   #3
What exactly do you mean by slightly larger?
Walker, Greddy, Tanabe, Megan, HKS, TRD, Borla, just to name a few are all on here. Best to search out historical threads to see experiences of members who have long since gone silent instead of relying on the relative few still active.
Old 08-30-2017, 01:43 PM   #4
Blitz Nur Spec. Biggest difference I noticed over others before I purchased was the lack of "popping" and that fart can sound, which is why I went with Blitz. Has a smoother deeper tone IMO and like I said, no popping, on revs or decelerating. Didn't need to modify anything to fit either, even with an Vitz RS bumper.
Old 08-30-2017, 02:14 PM   #5
DarkShadowFox
i dont know what to run from japan theres lots of options from the vitz side of things.
Sent from my LG-H918 using Tapatalk
Old 08-30-2017, 04:51 PM   #6
GibbsYaris07
just mean a slightly larger exhaust than the tiny factory exhaust. I'm not talking fart can noise, just appearance.. I'm thinking of just adding a tip. lol
The Gibbs Garage
Old 08-30-2017, 05:04 PM   #7
Just get a tip then. Plenty of nice stainless steel ones for around $10. No need to replace exhaust unless it's worn out.
Old 08-30-2017, 05:51 PM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
This SS tip is about $10 from Walmart... and it's the perfect length!
Pilot Automotive Round Slant Resonated, 3-1/2"
Just slip it over the tiny muffler outlet pipe until it meets the muffler plate, center it, then tighten with a wrench.
Had one on my '07 and now have one on my '14
Old 08-30-2017, 06:55 PM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Look inside the resonator...its a straight pipe. Show me the restriction? The second cat can be considered a minor restriction.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-31-2017, 07:12 AM   #10
^this is why I just deleted my first car (only for cold start emissions) and went with a larger diameter tubing and swapped the muffler for a deeper toned less restrictive one.
The resonator is not a restriction on the 1nz, the exhaust diameter, muffler and less so the dual cats are
Old 09-04-2017, 04:30 PM   #11
DarkShadowFox
theres dual cats?
Old 07-17-2018, 05:11 PM   #12
Julio Bro!
Drives: 2018 Yaris sedan
Has anyone removed just the OEM resonator, does sound becomes better?
Julio Bro! is offline   Reply With Quote
Old 07-17-2018, 05:58 PM   #13
Yes, but only because it had a hole in it.
Does it change the sound? Yes it does. An annoying buzz is introduced, which is why cars have resonators.
Old 07-17-2018, 06:07 PM   #14
Julio Bro!
Annoying buzz...got it; not good to remove it. Thanks.
Old 07-17-2018, 06:23 PM   #15
Runethecursed
Drives: 2009 Yaris S
I chopped the resonator out and straight piped it. backfires and burbles way hard now. more shrill than fart can, but it barely passes db sound tech. I actually want a quieter one myself
BUT it is possible! and when WOT sounds mighty (for a hamster)
Runethecursed is offline   Reply With Quote
Old 07-17-2018, 10:39 PM   #16
SirDigby
Drives: 2007 yaris 3 door
no. replace it with a higher quality one...
Old 07-18-2018, 01:21 PM   #17
Julio Bro!
Yes, I understand the advise, but, at least, it works at filtering unwanted sound. Just as in my WRX, the OEM resonator is straight and does a good job.
For now, we'll be looking for a better performance muffler with no drone. It seems there is no specific unit for the Yaris sedan, and ours is 2018. So, we'll take measurements and see what could fit from the still available Dynomax VT mufflers around. Also, from a post here, it seems that an IMCO Turbo muffler works too.
Old 07-18-2018, 02:58 PM   #18
dogsridewith
Drives: 2007 2-door hatchback
muffler tips
What does it do?
Exhaust Upgrade keegs Performance Modifications 1 09-10-2015 06:00 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
