Old 09-03-2017, 08:06 PM   #1
mhtm
Drives: 2009 Yaris 4dr hatchback
Fitting sedan bumper cover on hatchback
My daughter wrecked the front end of her 2009 Yaris 4dr hatchback. The junk yard said the hood and bumper cover from a sedan would work, but not the headlights. I bought them and installed the hood...worked fine. then started to install the bumper cover but would not quite fit over the headlights.
Can I use the headlights from the sedan? Also could carve out the bumper cover to fit around the lights. Trying to do the least expensive and simplest repairs so she can get back up and running.
Any thoughts?
mhtm is offline   Reply With Quote
Old 09-04-2017, 03:15 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Unfortunately, the junkyard told you wrong.
You need Yaris hatchback hood, bumper and headlights.
Since you already bought the sedan hood and bumper, I cant help you any further.
Old 09-04-2017, 08:59 AM   #3
mhtm
The hood, hinges, bumper and bumper cover fit perfectly...the headlights only slightly interfere with the bumper cover.
Old 09-04-2017, 11:19 AM   #4
Sedan headlights will not work with your HB fenders. The HB headlights are quite a bit deeper, extending much closer to the windshield than sedan lights do.
Old 09-04-2017, 11:47 AM   #5
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
If everything fits fine besides the headlight to bumper fitment, and you're looking for the least expensive repair, I'd say hack the bumper for it to fit. Then pick up the correct bumper in the future.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 09-04-2017, 11:51 AM   #6
Post pictures if you can. It must look slightly unique.
Old 09-04-2017, 12:12 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
I'm surprised the hood and bumper cover fit at all.
For a quick fix, it sounds like you could just trim the bumper cover and you'll be good to go.
I'd really like to see this.
sedan or hatchback for the snow. Ronancorcoran10 Canada 2 11-18-2016 04:10 PM
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
DIY Tow-Hook Cover Plate Mod Yarisduder DIY / Maintenance / Service 4 05-29-2010 11:51 PM
New Bumper Cover CB900F2 DIY / Maintenance / Service 6 01-18-2010 06:49 PM
