Old 09-07-2017, 11:22 PM   #1
eeeeeh
Drives: Yaris YR 2013
3rd gen indicator relay - is that built into the instrument cluster?
Hi all, newbie here, with a 2013 RHD Yaris (3rd gen) manual from Down Under.
I'm looking to replace the indicator bulbs (4 corners, not the side repeater) with LED, but so far digging through various forums only the 1st and 2nd gen Yaris has the turn indicator relay hiding on the left near the knee area. Saw another thread here that says in order to eliminate the hyper flash scenario after changing to LED, you must install resistor to each side of the car.
Can anyone second that? Is that my only option? thanks in advance.
eeeeeh is offline   Reply With Quote
3rd gen, hyper flash, indicator, led
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 03:09 AM
3rd Gen Gauge Cluster Swap :D KenTK808 Third Gen Yaris General Discussion 22 10-21-2017 07:58 AM
3rd gen SE and LE gauge cluster swap? m.flores.0928 Third Gen Yaris General Discussion 23 06-29-2017 10:30 PM
How to clean dash instrument panel? 3rd gen Tgawe DIY / Maintenance / Service 4 10-11-2015 05:09 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
