Old 09-15-2017, 06:50 AM   #1
Altec
Drives: Toyota Yaris Zinc 2007 SCP90R
Yaris Zinc 1.3 2007 P0121 CEL
Hi guys,
First time poster here in UK and it's the first car I have ever owned. Got a Yaris Zinc 2007 Feb this year and everything seemed perfect. One month on got a Check Engine Light, car went into limp mode and managed to limp home at 10mph.
Got to a local garage who cleared the code and said engine was fine, etc. Got robbed £55 in the process. Another month later got the same light but this time I bought an ODB scanner. Code is P0121 which relates to the Throttle Position Sensor.
Long story short, I replaced the MAF, Throttle Body, Air filter, Spark plugs, Oil and I'm still stuck. I can clear the code and run for about a month then it goes back to the CEL. I clear it and keep going a bit longer.
Finally stumbled upon something on honest john website:
"18-5-2012: Three identical faults reported with 2008 Yaris 1.3 SR models coming up as P0121 and requiring a replacement wiring loom costing £500."
So I contacted the dealer to get a quote. They have quoted me £4000 inc VAT!! The car was bought for £2000!
Even if I bought the part by itself they want £1445.
To make matters worse I have found a Toyota Service Bulletin that says if you get certain DTC codecs (P0121 being one of them) you need to replace the engine wiring with a new and improved part.
I don't see how people on the honest john website got it replaced for £500. I'm not sure what do to now. The care is great except for this one niggle.
Anyone got any advice, bar selling the car?
Altec is offline   Reply With Quote
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
