Old 09-26-2017, 04:24 AM   #1
rabbito
rabbito's Avatar
retuned with cam (injector)
just sharing from last thread that i have made
changed to 330cc for (E85) after maxing out injector (250cc)...change the spark plugs...radiator flush after cam(saw it from other post to flush the radiator due to stuck air after cam install)
redline 7,300rpm
113whp..about 140 crank..hyper dyno that their using lose about 3~5whp so add this to current whp..he said standalone will be close to 120whp..
same guy with MT makes about 123~125whp..1zz throttle body with manifold and hks intake 130whp..+3~5whp for dyno
weather todays about 40c / 104f...pretty hot today with humidity
i am pretty happy with the outcome
if you look at the dyno sheet...it also has no vvti taking off sensor just to run dyno hp...haha
thank you~
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 10-04-2017, 06:41 AM   #2
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
pretty good results for an Auto
Fluxtasy is offline   Reply With Quote
Old 11-07-2017, 01:03 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Keep revving the engine, there is another 10-15 hp in there. My peak HP with stock tb is at 7800rpm.
2014 BSpec Divisional Champion
Weird Injector Fault Lightyear DIY / Maintenance / Service 0 06-13-2017 03:24 PM
JUN Releases Camshafts for the 1NZ-FE changchewsoon Performance Modifications 53 01-23-2017 08:28 PM
Fuel Injector Bench Cleaning and Testing CTScott DIY / Maintenance / Service 2 05-31-2013 10:20 PM
FYI cam gear yaris9876 DIY / Maintenance / Service 2 05-25-2012 06:48 PM
