#1 |
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
changing front swaybar bushing
As anyone ever changed these, mine are due making lots of noise in the front. When to the dealership for a front end check. I had to changed those bushing and the sway bar end links. I was able to change the end links myself and I got the bushing and took them to my mechanic as he had to change the water pump. He only did one side as it was too hard and too much work.
So I'm going to try and change the driver side myself. So any tips or special tools I'll need? The front bolts looks easy to get to and is a 14mm. I hope the back is the same but trying to figure out how to undo the rear bolt. Also can I do just one side or I have to undo both side to get access to the bushing? Thanks. |
DKDC
Drives: Yarlet Join Date: Aug 2006
i had to drop the sub frame. its a bitch but not that heavy.
(dick measuring info goes here) |
#3 |
In between cities
Thanks for the reply. I got the bushing changed. I didn't remove the sub frame had to get a really long 14mm open and close end wrench, and a lot of patience. Each side took me 5 hours from start to finish. I think what helped is that I sprayed pb / wd40 every day for a week and half before I started the removal.
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Wow no idea how you were able to do this without dropping the subframe and not stripping the bolts.
I was going to replace mine last year for maintenance purposes but when I realized then work involved i figured I'd wait until they actually needed replacement. At 200k km mine are in fine shape.
#5 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
Mechanics will drop the sub frame to do it as it is much easier that way.
Sent from my SM-G930W8 using Tapatalk |
| Changing front speakers | Chucho72 | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 07-26-2012 10:53 AM |
| where to get front bumper and front bumper support | n.a. | Canada | 5 | 01-31-2012 01:33 AM |
| Ever tried removing the front swaybar? | Loren | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 44 | 11-23-2009 12:12 PM |
| What do you think? painting the front of a Yaris hb front bumper black like the GTI | Rnankoo | Cosmetic Modifications (Exterior/Interior) | 15 | 08-23-2009 05:49 AM |
| Front bra for S model Sedan? | N9QGS | DIY / Maintenance / Service | 2 | 06-27-2009 08:51 PM |
