Old 10-09-2017, 01:58 AM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Yaris Hybrid headlight and tail light compatibility
I have a 2014 US spec LE 4 door model. I recently discovered the fact that Toyota has a hybrid model of the Yaris in other countries. I also noticed that these models have really awesome looking headlights and tail lights. I want them!
Based on their basic outward appearance and shape, they look like they would fit any 12-14 US spec model as far as mounting locations, bolt holes, etc (but not the face-lifted 15+ models)
Are these actually compatible with US spec cars though? Any idea where I could get them? I need these in my life! I found an eBay posting for tail lights but no headlights. I’m going to hit up my local dealer to see what I can find. The search continues...
eBay Hybrid model tail lights
https://www.ebay.com/i/162472672119
m.flores.0928 is offline   Reply With Quote
Old 10-09-2017, 02:11 AM   #2
The taillights will probably need to be repinned and spliced into a USDM connector.
Headlights will not have the correct cutoff and you'll just end up blinding oncoming traffic here.
Old 10-09-2017, 02:12 AM   #3
m.flores.0928
Drives: 2014 Yaris
Repinning is fine. I can do all the necessary testing to figure out which pins is what, etc.
Headlights can be adjusted can’t they?
Old 10-09-2017, 02:16 AM   #4
Then I say go for it if you really want those taillights.
The only way to "adjust" a RHD headlight is to take it apart, and maybe flip the cutoff the other way. If that's not possible, then you would have to retrofit another set of LHD projectors (I'd look at the Retrofit Source for that).
Old 10-09-2017, 02:19 AM   #5
m.flores.0928
Drives: 2014 Yaris
Crap, it didn’t even occur to me that Hybrid models are probably RHD... hmm. Does that mean one headlight aims differently than the other? I thought they were more or less aimed the same way? What is this “cutoff” exactly?
I’m not necessarily wanting the headlights because they are projectors, I like them overall with the integration of the LEDs, etc.
Old 10-09-2017, 02:30 AM   #6
So you can see why you would end up blinding oncoming traffic with RHD headlights.
Old 10-09-2017, 02:32 AM   #7
m.flores.0928
Drives: 2014 Yaris
I see. I get the idea now. That first picture though is literally just a flipped copy of itself.
Anyway, I see. Well, can’t one of them be aimed down and one of them aimed up? I thought this cutoff was decided just by aiming them.
I recall seeing a LHD Yaris Hybrid somewhere around this forum, let me go see if I can find it
Old 10-09-2017, 02:35 AM   #8
Nope, if you aim them down enough to not blind oncoming cars, you'll have a useless headlight as you'll only throw the light maybe 20 feet in front of the car.
If they had a Yaris HSD in a LHD country, then your best bet is to find/source headlights from one that was destined for that country. lol.
Old 10-09-2017, 02:36 AM   #9
Also, does your current Yaris have DRL's? If so, then you'll have to repin it to the LEDs. If not, then you'll have to get creative on how you would want to turn on the LEDs. You'll also need a wire harness adapter (if they make one that goes from H4 [assuming that's what the 14s had] to what ever bulb base the Yaris HSD projector uses.
Old 10-09-2017, 02:54 AM   #10
m.flores.0928
Drives: 2014 Yaris
Gotcha
Yea I’ll keep looking.
Yes, my car has “DRL”, which is a position on my headlight switch. DRL in the “on” position just means my low beams are on, that’s it. It’s nota separate bulb or function. The LEDs in the Hybrid headlight presumably are the DRL, whereas the projector beam is the low/high beam separately.
Old 10-09-2017, 03:01 AM   #11
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
There are in fact Yaris Hybrids with left hand drive. They are all over Europe, so it should be possible to source the headlights from there.
Old 10-09-2017, 03:01 AM   #12
m.flores.0928
Drives: 2014 Yaris
Any idea how? I was simply going to ask a local dealer if they could help me out
Old 10-09-2017, 03:13 AM   #13
NYC-SE
NYC-SE's Avatar
You are going to have to find a company or person over there. Toyota USA does not stock and will not procure non US model parts, even if they are made by Toyota. I went thru this when I was trying to find mirror covers for my integrated mirror turn signal mod. I used a Japanese supplier but that won't work for you as Japan is RHD. I'm sure there's got to be something similar available somewhere in Europe but I don't have any idea who that is. Good luck.
Old 10-09-2017, 04:06 AM   #14
m.flores.0928
Drives: 2014 Yaris
Thanks! It will be a slow process but I’m sure I’ll report back whenever I make progress
Old 10-09-2017, 04:28 PM   #15
stykerdk
Yaris Hybrid Limited 2015
I have talen a Quick look and there isnt any lhd hybrid headlamps for sale yet.
You Can search eBay.de its called scheinwerfer in german.
But you might also need bumper and helmet i Think there is difference.
And the worst is these projectors have really poor light with the original HIR2 halogen bulb.
So you will have to find HID or LED to get Good light.
C-HR 1,8 Hybrid premium 2020
Old 10-09-2017, 04:33 PM   #16
m.flores.0928
Drives: 2014 Yaris
What do you mean “bumper and helmet”?
Old 10-09-2017, 05:14 PM   #17
I'm assuming he is talking about the crash bar/bumper reinforcement and/or brackets.
Old 10-09-2017, 05:15 PM   #18
m.flores.0928
Drives: 2014 Yaris
Aha, I see. Well, I would be able to know if there are differences if I could see the backsides of the housings.
Tail light parking light & license plate stop working SIRAY2 General Yaris / Vitz Discussion 1 06-03-2017 02:59 PM
Tail light from 2009-2011 hatchback on 2006-2008 body. alexistecnico Cosmetic Modifications (Exterior/Interior) 2 05-05-2017 01:39 PM
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 09:36 PM
Stock headlight and taillight for sale GabL Items for Sale by private party 11 04-14-2014 08:24 PM
FS: 09LB Bumper, Taillight, HeadLight, Side Mirror, parts, etc.. AlainMikli Items for Sale by private party 27 05-17-2010 10:04 PM
