Old 10-09-2017, 05:39 PM   #1
YarrrMate
Used 2012 Yaris - good buy or should I avoid?
Hey there! This 2012 Yaris came up near me for a good price 5,995 but my friend said I should probably avoid because it was a rental the first 2 years and rental companies don't really take care of their cars. What do you think based on the car fax - https://www.carfax.com/VehicleHistor...KTUD36CD526660
I kind of want a sedan anyways but trying to decide if I should check it out or just hold out for a sedan Yaris with a better history. Thanks
YarrrMate is offline   Reply With Quote
Old 10-09-2017, 06:59 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I rarely base a purchase decision on a carfax report/CarProof report. Record keeping is spotty and damaged vehicles are repaired all the time (off the books) and never appear on a report. I bought one car that had a clean report. Months later, I discovered that it had been in an accident. Nothing major, but could have been. Your report shows a long oil change interval by the first owner, but it may well have had an oil change and not made the books. I've never heard of a rental company - at least a reputable one - letting oil changes slide.
I have every intention of buying a used rental van when we replace ours. Generally, rental companies take much better care of vehicles than the average consumer.
I would take the car to a reputable shop and pony up a few bucks for a thorough inspection. And, then base your decision on that.
Old 10-09-2017, 10:02 PM   #3
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Two of my five Yarii were previous fleet or rentals. I'm sure I beat them worse as taxis than what they went through there.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 10-11-2017, 03:38 PM   #4
YarrrMate
Thanks for input! I will have a mechanic look at it before buying regardless
How did they hold up over time? Did you have to do a lot of repairs or no?
Old 10-11-2017, 05:08 PM   #5
Best vehicle in my 37 years of vehicle ownership, new or used, is my 2006 ex rental that I purchased in 2007. It is a misconception that rentals are beat to hell and not properly maintained.
Old 10-11-2017, 06:30 PM   #6
They are often sold before first maintenance is due.
Rentals often sees its limit right off the lot, but I don't think it really matters nowdays where most engines are reliable.
Sent from my SM-G930W8 using Tapatalk
Old 10-11-2017, 07:50 PM   #7
Dodge Aries K
Well, I've put 30,000 miles on my 2014 Yaris using it only for taxi type stuff and it's been 100% reliable.
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
