Old 05-23-2007, 06:34 PM   #1
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
Sqeaky Sqeaky...HELP
i now have almost 600 miles on my car. love everything about it except for a sqeak from my dash. sometimes when im driving down the road i get a sound comeing from my dash that sounds like a couple of mice of having at each other in my car. the sounds stop when i put my hand on the dash. my dad is pretty sure that its the dash rubbing against the plastic protecting the speedometer. i agree w/ him. i know its not a big deal but its just kinda annoying and makes the quality of my car seem less then what it is. anybody else have the problem and how did u solve it?
SLIK4 is offline   Reply With Quote
Old 05-23-2007, 07:19 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Mine doesn't do it, but I am more then happy to link you to schematics for dash disassembly procedure. You might just need to pull the dash apart and reassemble with care possibly using a shim along the way to correct it. Have you tried the old fashion approach of giving the offending area a good solid whack with you palm when it carries on? I have fixed more then a few rattles over the years with this method.
blacksan is offline   Reply With Quote
Old 05-23-2007, 07:38 PM   #3
SLIK4
Michael
SLIK4's Avatar
im not a repairman by anymeans. im only 17. i dont trust myself enough to work on my own car right now. im thinkin that if it doesn't stop that ill have the dealer take a look at it when i take it in for the first tune up. but thanx anyway.
Old 05-23-2007, 07:41 PM   #4
blacksan
blacksan's Avatar
No prob. Do you drive on a bunch of unpaved roads?
Old 05-23-2007, 07:48 PM   #5
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
If the Karate Chopping method above does not work I too would suggest taking it to the dealer and telling them to make it right.
SPONSORED BY
Old 05-23-2007, 07:58 PM   #6
SLIK4
Michael
SLIK4's Avatar
no but have several railroads around here that i drive over. i do try to slow down alittle when going over them. im still babyin my ride.
Old 05-23-2007, 08:03 PM   #7
blacksan
blacksan's Avatar
The only reason I asked is that gravel roads will shake the hell out of any car and make them squeak. Good luck with the dealer. If I can help with schematics, or what ever let me know.
Old 05-23-2007, 08:07 PM   #8
SLIK4
Michael
SLIK4's Avatar
thanx again
Old 05-23-2007, 08:28 PM   #9
Typer73
Tired of the Stars!
Typer73's Avatar
Drives: '07 Meteorite LB
If all else fails, turn up the stereo!
Typer73 is offline   Reply With Quote
Old 05-24-2007, 12:09 PM   #10
palsan
Drives: yaris 3 dr hatch
I have similar problem on my 3-door hatch.
The dealer attempted to fix it three times - all unsuccessful!
A few weeks ago I removed the centre console (official name is actually "rear console box assembly") and took out the plastic piece that covers the gap in the shift lever area (the "position indicator slide cover" for automatic trans). Noise gone for a while.
A couple of days ago - after a cold night - the noise was back in the morning but gone again in the afternoon. It may be due to expansion/contraction of the plastics in the console areas.
Unless I can isolate the problem before the cold weather returns its going to be a long winter again!
palsan is offline   Reply With Quote
Old 05-24-2007, 02:04 PM   #11
ChinoCharles
Drives: LB
Wasn't this brought up a while back? Didn't it end up being something related to the windshield mount?
Old 05-24-2007, 02:40 PM   #12
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Isn't there a TSB for a squeaky dash?
2006 Red Blitzed RS 5-door
Old 05-24-2007, 02:49 PM   #13
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
subscribing to thread
Vervepipes is offline   Reply With Quote
Old 05-25-2007, 11:43 AM   #14
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Ah, makes me miss my first vehicle, a '67 Dodge Power Wagon. Back in the old days, the dashes didn't squeak because they were metal, and bolted, and frikkin' WELDED.
Of course, should you ever have a wreck, your skull would smash to little pieces like a raw egg, but hey, those cars were built right!
(That Dodge did have a little pad that ran across the dash to "protect" your head, but I'm pretty sure the pad was still hard enough to bust my head open!)
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 05-25-2007, 08:04 PM   #15
Vervepipes
Vervepipes's Avatar
Drives: '08 Sedan
Thats what steering wheel flex is for!
Old 05-26-2007, 09:40 AM   #16
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
I had it during my first kms with the car and then it vanished!
