Old 10-11-2017, 10:36 PM   #1
yaristotle
Drives: Yaris Blue HB 5 speed
problem acceleration after battery jumpstart
Like the fool that I am, I left the lights on all day on my 2007 Yaris manual transmission and came back to dead battery. I had the battery jump started and now the car has problems on acceleration. Starting on, I have to press down harder on accelerator pedal to get going and when I shift, I also have to press down a little more and shifts are not as smooth. Any idea of the problem and solution?
yaristotle is offline   Reply With Quote
Old 10-11-2017, 11:53 PM   #2
yarisimean
Drives: 2012 Yaris 3d LB
Maybe the computer has to relearn how you drive since yaris has an electronic throttle. As for the not so smooth shifting, I have no idea but I find it unlikely that it has to do with the electronics since you are the one doing the shifting.
I'm just spitballing. I'm interested to know what it is.
yarisimean is offline   Reply With Quote
Old 10-13-2017, 04:45 PM   #3
I imagine by now the OP no longer has an issue. Whenever the battery has been drained or disconnected, the ecu goes through a learning phase. Until it figures everything out again, you experience extremely low and erratic idle.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
Tests fail to duplicate acceleration problem in Prius JBougie Off-topic / Other Cars / Everything else Discussions 36 03-29-2010 03:34 PM
I think it's a battery problem.. don't you ? jorizk DIY / Maintenance / Service 10 08-11-2009 02:27 PM
