Old 10-17-2017, 08:47 AM   #1
Sakis Deme
Drives: Toyota
Valve timing help
Dear all members,
I would like to ask for your help. I am mechanic engineer and PHD student.
I am creating a model of the engine of Toyota Yaris 1ND-TV euro 5 diesel 1364cc.
I know the opening and closing of both valves (intake and exhaust)
Intake: open 4 deg BTDC
close 36 deg ABDC
Exhaust: open 44 deg BBDC
close 4 deg ATDC
However i have difficulties in valve lift. I can't find the valve timing (valve lift per crank angle degrees CAD).
Is there anyone that could help me, i need the valve lift (mm) per CAD of both valves in order to insert to my model the plot of valve timing
Thanks for your time
Sakis Deme is offline   Reply With Quote
PCV VALVE THREADS DANIELTNIEVES DIY / Maintenance / Service 3 08-17-2015 03:11 PM
Stock (factory) yaris Timing ? salmanghiyas Performance Modifications 44 03-29-2015 03:50 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Variable Valve Sensor Error Craig DIY / Maintenance / Service 13 06-22-2013 03:29 AM
