Old 10-18-2017, 10:25 AM   #1
eeeeeh
Drives: Yaris YR 2013
how to replace original brake light with LED?
Hi there, just wondering if anyone has done the conversion of original brake light (dual filament) with LED. I have already replaced the indicators, reverse lights, and all interiors, and want to complete the project by replacing the brake lights. As you might know the original bulb is dual filament and therefore, two different currents would go through the bulb. With LED pulling in so little power I've read that current would back-feed through the low-beam light and turns on other lights. I'm assuming I'd need to fit some diode in-line to prevent back-feeding power, but I'm unsure what diode to get nor the fitting of it.
Would appreciate if anyone has that knowledge can chime in. Thanks in advance.
eeeeeh is offline   Reply With Quote
ABS light on (without parking brake light) WildChild DIY / Maintenance / Service 15 05-06-2018 12:40 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
2007 yaris hatch back 3rd brake light (stop light) MegaMatt DIY / Maintenance / Service 12 06-15-2015 10:55 AM
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
