#1 |
Drives: Vitz 99 Join Date: Oct 2017
Window doesn't go all the way up, central locking doesn't work
Hi everyone, I have a Vitz 99, I'm facing 2 problems with my Vitz, one is that the Automatic drivers window sometimes work, sometimes doesn't, either it will go up, either all the way, or in a place I stopped it, or vice versa and stop, and can stay like this for 5-10 minutes till I can move it again. I have noticed that, there is a clicking sound in the motor but the window doesn't move, it does get affected by the warmth, the warmer it gets the longer it works, if it's cold I have to put the heater on full to work again.....
I thought it was the motor, so I changed it with a new one, the problem is the same..... That's the one problem Second problem, the central locking randomly works, like it can close all doors, sometimes one door, sometimes none of them, and vice versa in closing it, I did notice that if i use it like 3-4 times the sound on the locks seems like they are running low on battery, the battery is new... Any ideas??I don't want to take for a repair till i know a bit about the problem (Last time I took it to an electrician and he isnisted that I needed to change the alternator, but it was just the battery) Thank you |
| Remote central locking fault | littletomy | UK | 0 | 05-18-2017 11:34 AM |
| Central Locking Wiring | derekdsl | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 03-08-2015 10:36 AM |
| HELP. yaris drivers electric window not working | spiros26 | DIY / Maintenance / Service | 4 | 01-08-2013 06:34 AM |
| Power window | mamun22s | DIY / Maintenance / Service | 1 | 08-30-2012 07:35 AM |
| Window Sticker | Stoln | General Yaris / Vitz Discussion | 10 | 07-14-2007 01:01 AM |
