Old 10-21-2017, 01:42 PM   #1
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
KENWOOD KSC-SW11 on Yaris 2013
Hi
Im planning to install Kenwood KSC-SW11 on my Toyota Yaris 2013 5 door.
This is the wiring diagram for the same subwoofer.
I have the pin diagram for Touch and Go
As explained in the pin diagram pin no 3 on 10 pin connector should connect to Blue/White wire from subwoofer (Accessory line 12V)
subwoofer front/rear left go to pin no 2,6 on 10 pin connector or pin no 2,6 on 6 pin connector
and
subwoofer front/rear right go to pin no 1,5 on 10 pin connector or pin no 1,3 on 6 pin conncector
*Front or Rear which one will give better output for subwoofer
Black wire from sub is ground.
Yellow wire from sub go to fuse box +
Could you please help me to find which one is that fuse box and how to connect. Also any one please confirm the above explained is correct method.
HDTechVideo is offline   Reply With Quote
Old 10-21-2017, 06:59 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
eh, i have a SW10 and installed an SW11 not long ago to a scion xd. I used a thicker cable and connected the yellow direct to the cable, which is connected direct to the battery terminal under the hood.
The kit allows you to use the yellow with fuse and connect direct to battery, there's more than enough slack to do so.
Old 10-21-2017, 07:28 PM   #3
HDTechVideo
Thank you. Just saw a video on yoitube and he is doing the same. Ehat about the pin connection explained above? is tgat the right info. Which channel is best for sub, front or rear?
Old 10-21-2017, 07:34 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
pins look good, I used aftermarket headunits so i connected the sub with stereo RCA cables. If you're splicing the stock radio, I would do fronts, especially if you're dropping the sub under front passenger seat.
Old 10-23-2017, 07:50 AM   #5
HDTechVideo
Thank you. installed it successfully.
Old 10-23-2017, 06:06 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
Old 10-24-2017, 03:51 AM   #7
HDTechVideo
I got this cable from Halfords , so it was easy for me to connect the sub cables.
2013, digram, subwoofer, wiring, yaris
2013 Yaris SE - What to mod? roachslayer Third Gen Yaris General Discussion 9 05-07-2017 04:56 AM
2013 Yaris headliner for sale Smog7 Items for Sale by private party 4 03-04-2017 10:53 PM
rear spring replacement 2013 Toyota Yaris (NCP130) williew2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-27-2017 12:46 AM
