Old 10-23-2017, 03:02 PM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
brake drum/shoe replacement
Im looking at replacing my brake drums and shoes (in the rear, of course)
Should I go full factory parts from the dealer? Or can I get decent aftermarket OEM parts from AutoZone?
Thanks!
m.flores.0928 is offline   Reply With Quote
Old 10-23-2017, 04:00 PM   #2
After market should suffice, there are plenty of decent quality aftermarket brake options out there for the yaris. Rock auto has a hand full.
You have a '14 yaris, there is no way you should be needing replacement of your shoes/drums already. Have you inspected them and determined they need replacement?
Old 10-23-2017, 04:05 PM   #3
m.flores.0928
Drives: 2014 Yaris
You’re right. They don’t “need” it. I just rotated my wheels yesterday and looked at them. My issue is that they squeak like a motherf***er and I can’t get them to shut up. I’ve tried backing off the parking brake, cleaning out brake dust, mild resurfacing using sandpaper by hand, anti-squeak spray stuff, nothing works. I haven’t had them professionally machined and resurfaced but I’ve seen how inexpensive drums and pads are so I might as well replace the whole damn thing.
I hate drums. #ShouldHaveBoughtTheSE
Old 10-24-2017, 06:03 PM   #4
yaris2010RS
yaris2010RS's Avatar
wait the SE has disks in the rear?
Old 10-24-2017, 06:14 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Damn right. That's why I bought it.
Old 10-24-2017, 07:45 PM   #6
m.flores.0928
Drives: 2014 Yaris
Yessir. Don’t remind me
Old 10-24-2017, 08:56 PM   #7
I can't speak directly about what is causing your squeak but I've always had luck by applying a brake specific grease to the friction points on the drums and have yet to have a squeaking issue with my yaris, vibe or retired Echo.
Check the repair manual to ensure you are applying it to the proper areas
Old 10-25-2017, 12:12 PM   #8
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I'm sure, like most things, it's debatable, but I've gotten the impression from the majority of folks I've talked to about it (on and off the forum) that on a car as small/light as the Yaris, rear discs are of no significant benefit.
My car is 10 years old, north of 70k miles, I do not granny drive it and I'm on the original, factory brakes. They've never made a sound. Having said that, when it's time to replace, I would also consider using aftermarket parts because it seems like there's some better quality aftermarket stuff out there for the price of OEM.
On Instagram
On Wheelwell
Old 10-25-2017, 03:24 PM   #9
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Old 10-25-2017, 09:21 PM   #10
YarTed
Drives: 2015 Yaris 5Dr
The wheel above and the rear discs sure do look great and I'm sure work well. I am very happy with my 2015 ( 66,000 KM ) Yaris rear brakes with the shoes. The car stops quick, no rear brake noise. The only problem I had was the paint on the drums flaking and a little rust after winter. I painted them up nice Rust-oleum high heat black. I expect over many many miles drums will be cheaper to operate. Looking at the wear on my shoes I expect will go well over 100,000KM .When time comes to change I will use OE. As that's what would have gotten me that far . cheers
YarTed is offline   Reply With Quote
brakes, drums, oem, shoes
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Replacement time, and brake bolt rubbers question BennyLava DIY / Maintenance / Service 11 08-27-2016 08:26 PM
Question about brake booster replacement RutherfordmanX DIY / Maintenance / Service 1 01-09-2016 12:34 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
