Old 10-24-2017, 02:20 PM   #1
yaris2010RS
yaris2010RS's Avatar
car stuck in acc mode?
got an interesting issue, when I turned the car off last night and pulled the key out, the radio stayed on.
the problem appears to be something with the key cylinder. I did verify the key was turned all the way back. I proceeded to turn the key on and off about a 10 times and everytime the radio stayed on but the radio would flicker off then back on. I ended up getting it off by jiggling the key as I turned it in the off position.
the proper fix is mostlikly to get a new cylinder which I don't overly want to do, has anyone else ever had this issue?
2010 yaris w/ immobilizer
Old 10-24-2017, 03:29 PM   #2
Not sure if cleaning the cylinder will help.
I've definitely seen this happen with my Echo. It was a year old with less than 30k km back then.
Although z I've never seen it happen with my Yaris.
Sent from my SM-G930W8 using Tapatalk
Old 10-24-2017, 05:52 PM   #3
yaris2010RS
i debated cleaning the cylinder, but what would be safe to put in there? a little wd40? white lithium grease? dielectric grease?
Old 10-25-2017, 09:54 AM   #4
Is it just the radio? Did you check if your 12v power outlet shuts off? There could be a short in the power circuit of the radio keeping it on.
Old 10-25-2017, 05:26 PM   #5
yaris2010RS
the radio and the 12v outlet stay on.
wonder if there is a relay I could check....CT Scott still around on here?
Old 10-25-2017, 05:29 PM   #6
In not sure ACC is powered through a relay.
Do you have any accessories you've added to the car that you've tapped into the ACC circuit.
Old 10-25-2017, 05:32 PM   #7
yaris2010RS
not that would cause the problem, a second 12v power outlet was added but was tapped off the first one and mounted right beside it.....
That being said, the car has been driven a few times and it did not get stuck in the ACC mode at all......might just peg this one as aliens till it does it again lol
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 05:19 AM
Gwasabi (Yoshi) - Photo-Scavenger Hunt! gwasabi Photo-Video-Media Gallery 24 03-07-2009 12:23 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
