Old 11-05-2017, 02:35 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Yaris MPG Drop
Anyone notice this. Yaris is about 9 years old, I replaced the original plugs on them about three years ago with NGK BKR5EIX11 Iridium IX with ones I got on sale from canadian tire. Since then, I have put around 70k on them. Pulled them out and they dont really look worn. Cleaned them off and reused them. Air filter is clean, and throttle body I cleaned probably 20-30k ago.
I also do the occasional fuel injector cleaner which I doubt has much effect anyways.
xdarkxfirex is offline   Reply With Quote
Old 11-05-2017, 03:26 PM   #2
ex-x-fire
Dirty maf or engine running cooler (bad t stat).
Old 11-05-2017, 05:13 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
Colder weather drops tire pressure (gas law) and stiffens tire rubber. Also thickens lubricants and delays warm-up.
Old 11-05-2017, 05:30 PM   #4
Your local gas stations may have also switched to a cold temp/season/winter blend, which always causes a drop in mpg. Check you tire pressure as well.
Old 11-06-2017, 09:55 AM   #5
Yeah, mine has dropped too. My bet is on winter gas already.
? Drop oil pan to check pump pickup screen Toyota Yaris 1NZFE dogsridewith DIY / Maintenance / Service 13 10-23-2017 07:45 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
