Old 11-07-2017, 07:05 AM   #1
ashique
Drives: Toyota Yaris 2013
Thin Metal Sound While Braking But Not Always - Any Idea Why
I have a Toyota Yaris 2013 Model. I used to hear a thin metal sound (same sound like when we collide two coins) most of the time when I brake. Any idea what is the possible reason ?
Thank you.
ashique is offline   Reply With Quote
Old 11-08-2017, 05:08 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
How thick is the remaining friction material on your brake pads?
You might have to remove the wheels to check but I can see mine throught the alloy wheel spokes.
Although you say "I used to hear", can you still?
mrpj is offline   Reply With Quote
Old 11-08-2017, 05:46 AM   #3
Miles on the car/brakes? I suspect it is just the pads re-seating themselves when the brakes are applied.
Old 11-08-2017, 10:20 AM   #4
ashique
I could not see the brake pads clearly. Sound seems to be coming from front wheel. Yes, I hear the sound once a while when I apply brake. Planning to visit a servicing center to check it. Thanks for your reply.
Old 11-08-2017, 10:24 AM   #5
ashique
Even when I drive in lower speed, sounds used to come once a while. Front wheel brake pads were replaced last year. Been driven around 5000 Km after that. May be. Thanks for your feedback.
Old 11-09-2017, 05:09 AM   #6
mrpj
Was everything lubricated properly when the pads were changed? Could be something sticking occasionally. Has it only done this since the pads were changed?
Make of pads and their friction material might have some bearing too.
Old 11-09-2017, 09:53 AM   #7
ashique
I think so. This sound is start coming since few months ago only.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
New brakes, squeak sound at front brakes Vesper DIY / Maintenance / Service 3 09-09-2016 03:02 PM
Humming Sound on Transmission Uno DIY / Maintenance / Service 0 01-29-2016 06:54 AM
Raising the sound stage... SAV912 In Car Entertainment + Electronics (audio / video / alarm) 11 07-30-2011 05:26 AM
