11-19-2017, 04:45 PM | #1 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
easy warm air intake
I did a warm air intake today, the snorkel on the air cleaner housing pops off and leaves you with a section of 3" tubing, so you can slide on the duct right there. I ran it over the valve cover to a piece called a saddle vent. I wedged this onto the exhaust manifold. I don't think I'll need to bolt it down as its fits pretty good.
11-19-2017, 05:44 PM | #2 |
Here's some pictures.
11-19-2017, 07:06 PM | #3 |
Drives: 2014 Yaris SE Join Date: Apr 2014
And why?
11-19-2017, 07:56 PM | #4 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
This post goes well with the muffler bearing and blinker fluid videos on line. I seriously don't know if you're just screwing with us or not...
No one ever wants to give a Yaris the point by... |
11-19-2017, 08:40 PM | #5 |
Drives: Toyota Yaris RS 2011 (HB) Join Date: Sep 2016
Wtf
Sent from my SM-N910W8 using Tapatalk |
11-19-2017, 09:32 PM | #6 |
I don't know about you guys, I see a pretty big change in fuel economy during the winter. I know some of it from the fuel additives, but most of it is from the cold air. While its great for power it really impacts fuel mileage. Its something I won't use in the summer.https://en.wikipedia.org/wiki/Warm_air_intake
11-20-2017, 12:10 AM | #7 |
Warm air should effectively reduce fuel consumption, but too hot will cause detention and cause the timing to pull back, greatly reducing power and fuel economy.
11-20-2017, 08:33 AM | #8 |
The theory is the ecu reduces fuel when the intake air is warmer as the air is less dense so it needs less fuel for combustion.
Although most of that is true all this does is reduce engine power. So there is zero increase in efficiency you just effectively reduce power. This makes you need to give more throttle to do the same work which negates any benefit. In such an efficient engine as the 1nz you just need do have a lighter right foot and you'll get excellent mileage. You are not limited in mileage with this car due to engine size and fuel demand, you are limited simply by the driver themself and how they choose to drive.
11-20-2017, 11:02 AM | #9 |
**duct
11-20-2017, 03:38 PM | #10 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I would do nearly the exact identical thing during winter time for mpgs.
The results were typically 3-4mpg gains from this mod. Back when i liked getting over 50mpg average for a tank. Now I dont care anymore and dont hypermile like I used too
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
11-21-2017, 02:09 PM | #11 |
Oh yes, thousands of engine specialists on highly paid development workplaces are daily introducing complex, bizzar solutions to improve the mpg thus reduce the emissions... and nobody came up with an idea of heat-hose. They are all nothing but a bunch of losers! :D
11-21-2017, 07:18 PM | #12 | |
Obsessed with 1.5L
11-21-2017, 08:11 PM | #13 |
11-22-2017, 02:51 AM | #14 |
11-23-2017, 02:06 PM | #15 |
I scanned the car last night, the air temp was 27*f, after starting and running for a minute the IAT was reading 60*f. Going down the road it bounced between 45 and 60*f before settling at 53*f. At stops it would go up 70-80*f. If anything it'll save gas when idling in snowy days.
11-23-2017, 03:22 PM | #16 |
Drives: 2006 Yaris RS Join Date: May 2015
I just lol'd
11-23-2017, 03:43 PM | #17 | |
11-24-2017, 04:29 PM | #18 |
It will not help anyhow. Cold start means that the exhaust pipes are also cold, so is the air. Before it heats up significantly to get into the pipe and all the way through the frozen airbox then the engine runs already so hot that the air temperature is insignificant.
Similar Threads | ||||
Cold Air Intake... | I PHANT0M I | General Yaris / Vitz Discussion | 2 | 01-31-2012 02:22 PM |
The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-06-2009 11:37 PM |
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
guess what I'm waiting for and how much I paid? | Ric n Sov's Vitz RS | General Yaris / Vitz Discussion | 27 | 06-27-2007 07:36 PM |
