Old 11-25-2017, 04:45 PM   #1
mr_robot
Sort of successfully finished my PKE install!
PKE - Passive Keyless Entry System:
https://rover.ebay.com/rover/0/0/0?m...2F332460280380
There are similar products on Amazon for double the cost but you will probably get better customer service.
So I say sort of finished because my remote start feature doesn't work properly. It will start the car but it stalls right away and I can hear the starter grinding the flywheel before it stalls.
But other wise it's trueley keyless go. I have unplugged the ignition harness and cut a spare key I had to prevent it from locking.
Used a plug that Inhad left over from the power window install and worked out perfectly!
mr_robot is offline   Reply With Quote
Old 11-25-2017, 09:04 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That is awesome! Thanks for posting.
My 08 has a command start (aftermarket) and keyless entry. I cannot get used to putting the key in the ignition and as soon as I touch the break and prepare to select a gear, it shuts off and locks the doors on me. I gets me EVERY time!
Old 12-26-2017, 07:02 PM   #3
mr_robot
Bought some Toyota logo decals for keyfob, looks hella OEM haha
Sent from my iPhone using Tapatalk Pro
Old 01-11-2018, 03:31 PM   #4
kaiomatico
Drives: Yaris XP9 1.33 2008 pre-faceli
Wow I'm trying to attempt the same, could you please send me some pictures of the wiring? Would be super kind! :)
kaiomatico is offline   Reply With Quote
Old 01-11-2018, 03:49 PM   #5
mr_robot
I did not take any unfortunately. I was using the DIY remote start guide for all the wiring and pictures.
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
Finished my install ........Finally DARKYARIS In Car Entertainment + Electronics (audio / video / alarm) 25 05-13-2007 03:52 AM
