Old 11-26-2017, 03:50 AM   #1
heytim
Drives: 2014 Yaris
Adding 12volt cigarette lighter to rear
So I'm wanting to add a 12volt cigarette outlet to the trunk of my Yaris, to power a next-to-be-installed rear facing dashcam.
(I figured adding a 12volt cigarette outlet in the hatchback trunk, then using the dashcam's included 12v cigarette adapter, would be easier than hardwiring)
To install, I think I would just need to get a female socket like this one:
https://www.ebay.com/itm/131333723351?rmvSB=true
Then I can run the positive/negative wires (or ground the latter) to the front, and hook it up to the fuse box using an add-a-circuit? I probably only need the outlet to have power when the car is on, so I would find & tap into an switched fuse outlet.
That's my understanding on how I would go about doing so, but I'd appreciate confirmation if this is correct and any suggestions/advice! Thank you.
Oh, and I drive a 2014 Yaris hatch, in case that makes any difference.
heytim is offline   Reply With Quote
Old 12-22-2017, 10:03 PM   #2
Janviernes
Drives: 06 5door
Sounds about right. Let us know how it goes, or if you have questions.
Janviernes is offline   Reply With Quote
Does the Yaris Hatchback 2007-2008 have Cigarette Lighter Port? TwisteD General Yaris / Vitz Discussion 10 08-13-2015 04:15 AM
Tried to replace cigarette lighter fuse, think prongs are stuck inside. Help please? wiirenet DIY / Maintenance / Service 10 01-31-2013 07:31 PM
Someone have any idea of adding rear foglights? TitaniumBarbell Cosmetic Modifications (Exterior/Interior) 3 06-01-2009 11:20 PM
Adding 2 Rear Speaker to Yaris CE edition. alexzz44 In Car Entertainment + Electronics (audio / video / alarm) 4 12-02-2008 12:04 AM
