#1 |
![]() Drives: 14 yaris Join Date: Nov 2017
Power charger not working?
I looked at both fuse boxes under the hood and didnt see anything I thought was related to the lighter/power outlet, and googling has resulted in foreign owners and fusebox locations my USDM car doesnt have. There HAS to be a fuse to check, and the detailed fuse diagram I found online seems to indicate the charger is integrated into the instrument cluster, but all that works still. Either I am not aware of the corresponding fuse, or there is a mechanical failure (it conked out in the middle of a trip, I use a dash cam, if that helps).
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
There is another fuse panel under the passenger side dashboard. Fuse number 15 in the panel is labelled "CIG". It is listed as providing power to "power outlet, cigarette lighter", and is rated at 15 amps.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
That will probably be under the driver's side in the U.S. Kevin. I don't think there's any trim to remove like RHD cars. It's just a matter of standing on your head and removing the fusebox cover!
#4 |
![]() ![]() Drives: 47 2013 yaris l hatchbacks Join Date: Nov 2016
Instrument panel junction block. 15A(Blue) CIG. Fuse. (Highlighted in yellow) instrument panel Junction block is located forward pf the driver's right knee approximately 3 inch forward of the OBD2 connector
![]() Sent from my Nexus 6 using Tapatalk |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 07:55 PM |
