Old 12-10-2017, 05:14 PM   #1
DevilzMafia
Drives: Toyota Yaris 2007
Oil on Spark Plug threads
Just took out the plugs for the regular replacement, and for the first time noticed oil on the spark plug threads.
To note:
1) Doesn't throw blue smoke or drink oil (so I doubt it's the rings)
2) Doesn't smoke at startup either
So I was thinking valve gasket cover or valve stem seals?
What do you guys think?
Linked the image here: https://ibb.co/hv2rUb
DevilzMafia is offline   Reply With Quote
Old 12-10-2017, 07:17 PM   #2
Most likely your valve cover gasket. Oil coming from up top then leaking down through threads. Valve stem seals typically cause blue smoke after idle due to the higher vacuum at idle iirc. Stem seals also are not known to go on the 1nz.
Replace the valve cover gasket and you should be good to go
Old 12-10-2017, 08:14 PM   #3
DevilzMafia
Thanks bro, I appreciate your advice!
Mazda to introducting spark plug less engine. junorico24 Off-topic / Other Cars / Everything else Discussions 3 08-19-2017 06:32 PM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 10:59 AM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 05:23 PM
