Old 12-14-2017, 09:01 PM   #1
chaditotx
Drives: 2007 3dr hb 5sp
2012 Se Hatch no cargo lamp after LED install
Installed an LED in the cargo area, because stock bulb was so dim. I did it with the hatch open, and power to the circuit. The LED came on , but went off as I was installing it. I put the factory bulb back in, and it will not light up. Anyone have any similar issues? The fuse for the interior lights is good, as my dome lights work just fine. I searched quite a bit and only came up with similar issues in a Prius. https://priuschat.com/threads/no-fus...-light.118844/
chaditotx is offline   Reply With Quote
Old 12-14-2017, 09:43 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Put a meter on it. Are you showing voltage?
Old 12-15-2017, 12:23 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Cargo area lamp Yaris. no-fuse damage. Mind of Toyota
No problems 16 months now w/ bright white 1 watt Sylvania Zevo #6418. (Looked for this over concern that the stock 4 watt bulb would drain battery during long hatch-up intervals when parked...to dry out after the Yaris leak thing, or wet dogs, etc.)
(Cargo area lamp Toyota Yaris)
re: Prius thread-- Wow. (and note that my 2007 cargo light does not go off after 20 minutes on either bulb type)
Old 01-21-2018, 08:14 PM   #4
chaditotx
Slight voltage is present at connector. There seems to be no fuse for the hatch light, it is switched on by the computer. Looks like I will have to jumper it from my dome lamp.
How to install day led lights? miiser Cosmetic Modifications (Exterior/Interior) 0 02-22-2017 08:33 AM
WTB: 2012 Yaris Hatchback Cargo Cover/Shade jpwhitewolf Willing to Buy by private party 0 05-06-2014 03:59 PM
WTB Cargo Cover for 2009 LE Hatch Yaaaris Willing to Buy by private party 0 08-23-2013 07:53 PM
Weathertech Floormats and Hatch Cargo Carpet brentbent Items for Sale by private party 7 06-18-2011 09:24 AM
Hella LED Combination Rear Lamp for Yaris Sedan!!! blackgenius007 Cosmetic Modifications (Exterior/Interior) 17 01-05-2010 12:51 AM
