Old 12-17-2017, 07:51 PM   #1
billfires
Drives: 2010 3dr LB
195/65R-15 tires
Anyone running 195/65R-15 tires on their stock rims? I run 195/60-15 studded snow tires in the winter, but only mount them when a sizable storm is predicted. Any info is welcome. Thanks, Bill C
billfires is offline   Reply With Quote
Old 12-18-2017, 12:12 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
A 195/65/15 is 5.5% larger in diameter. It would affect fuel economy and acceleration. I currently run 195/55/15 on my Yaris.
Old 12-18-2017, 12:30 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
My neighbour ran 195/65/15's on his 2007. They were HUGE!
Old 12-18-2017, 06:59 PM   #4
nortonfb
Drives: 2007
This is my 3rd season running 195/65/15. Running General all season for the winter.
Never had a problem with a little careful driving. Been through a few good snows.
nortonfb is offline   Reply With Quote
Old 12-19-2017, 02:34 PM   #5
Thirty-Nine
I'm just curious: Why would you run 195/65/15?
Old 12-19-2017, 05:28 PM   #6
nortonfb
Drives: 2007
Most of the time the roads are dry and I'm a little aggressive.
Old 12-20-2017, 05:29 PM   #7
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
195/65R-15 tires
I have 195/55/15 on mine as well. Stock steelies, but I also have wheel spacers. 25mm front, 30mm rear. It rubs in the back.
m.flores.0928 is offline   Reply With Quote
Old 12-20-2017, 07:43 PM   #8
billfires
Drives: 2010 3dr LB
I want to try the larger tires on my stock rims as a bridge between my 185/60-15 summer tires on aluminum rims and the 195/60-15 studded snow tires on stock steel rims. As I have found in the 2 small snow storms we have had so far the summer tires are horrendous. The studded snows are not very good when it is above freezing on non snow covered roads. Bill C
Old 12-22-2017, 06:01 PM   #9
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
You really shouldn't have a problem with 195/65/r15, but why don't you just go with 185/60's ? Narrower tires are better in snow anyways and they are usually cheaper.
What's the point of upsizing?
DiCaprio is offline   Reply With Quote
Old 12-23-2017, 11:57 AM   #10
http://www.yarisworld.com/forums/sho...ghlight=taller
Old 01-26-2018, 07:33 PM   #11
billfires
Drives: 2010 3dr LB
So I had my Hankook Optimo 724 tires mounted today. These are the 195/65R-15 tires that I got on Walmart.com for $45.33/tire. It was $58.00 all in for mounting, lifetime balancing, lifetime rotation, TPMS rebuilds, and tire disposal. Before they mounted them they confirmed that I knew they were larger than the original tires. I only put about 30 miles on them but my initial impression is they ride a little bit better than the original tires. Bill C
Old 01-26-2018, 07:38 PM   #12
m.flores.0928
Drives: 2014 Yaris
Nice, good to know. Does the taller tire have any other noticeable differences? Any rubbing?
Old 01-26-2018, 07:57 PM   #13
kimona
kimona's Avatar
Post some pics of your car on 195/65/15's.
Old 02-01-2018, 02:05 PM   #14
billfires
Drives: 2010 3dr LB
No rubbing, acceleration is slower. Bill C
Old 02-01-2018, 04:21 PM   #15
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
I run 195/60R15 on my 2014 Yaris that I use for work. I noticed it's a little slower than the other's at acceleration because of it but the mileage hasn't suffered. Main reason for getting them was the clearance pricing that Walmart had... Bridgestone Ecopias for $22 a tire... sadly they only had four or I would have bought more and I've called every other walmart I could find within two hours and they were all sold out.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 02-01-2018, 04:54 PM   #16
greyg00SE
Drives: '08 Yaris, '00 Miata,
Same here
greyg00SE is offline   Reply With Quote
Old 02-08-2018, 05:54 PM   #17
billfires
Drives: 2010 3dr LB
I figured out how to attatch the pictures but can not figure out how to resize them. Sorry, Bill C
Old 02-08-2018, 08:12 PM   #18
kimona
kimona's Avatar
This is an easy to use picture resizer:
http://picresize.com/edit
Click "Browse"
Open your pic to be resized
Click "Quick Resize"
Chose 75%, 50%, or 25%
Click "I'm Done..."
Click "View Image"
Save your resized photo to your file.
First impression - Hankook Ventus S1 Evo DiCaprio Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-22-2020 09:51 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
